csehdaniel
Hungary
Hi,
Problem is I can't see anything in GO app. Also I can't do firmware update/downgrade (is there any method to force fw update?).
symptoms (updated):
- gimbal works for a while (maybe 15 secs), meaning it compensates movement, then goes limp
- app says No Signal, live view is black
- if I move the dead camera by hand, I can see the feedback of the rotation angle in the app (but I can't move the camera from the app or the remote)
- RC is paired, so I can take off
- gimbal led is flashing green then flashing green/red - these two phases loop
- turning the AC off takes much longer time than usual, about 10 seconds
- does nothing on gimbal auto calibration (says ok in app, but doesn't move at all)
- sometimes the AC makes a double beep (DD) forever, sometimes there are just a few of these beeps then silence, sometimes no beep at all, I couldn't find any consistency about it
- AC has 1.8.80 fw on it and I can't downgrade or upgrade as the process never starts. I have tried it with several microSD cards. Card formatted (fat32), .bin file placed in root, no .txt, battery over 50%- camera related buttons and Menu are greyed out, so I can't even format inside AC
- app says 0MB remaining capacity on SD card (tried many of them) which would indicate that the gimbal's card reader may be faulty, but if I insert an empty card it creates the default folders
Any suggestions would be much appreciated.
