A3 with Graupner Receiver
2624 4 2016-6-29
user796f7b389f
Hello Forum, hello DJI,
have the problem with the A3 CTRLER, can not connect the Graupner receiver  with the A3, use the D-Bus Adapter and go to the sbus slot. no function, have tried everything. has anyone a solution. can someone help me.
-transmiter ist set from sumo to once
Greetings from Germany
Mario
2016-6-29
user796f7b389f
Oh the DBus adapter, just had to change the direction. now that was new to me.
2016-6-29
DJI-Jamie
Flight distance : 112405 ft
user796f7b389f Posted at 2016-6-29 18:21
Good to hear you were able to get yourself up and running.
2016-6-29
Clancey
Flight distance : 8665 ft
I see you can tab over on the channels, Can you configure more channels other then what is on that channel page. when using S-bus rather then LB2?
and are your A3 f ports working?
2017-3-30
bernde
Austria
Hello,
I am having the same issue with my N3 and a Futaba SBUS Adapter SBE-1 connected to a Yeti Duplex Receiver. There  is no signal when I open the DJI Assistant 2 software. I think cabling is ok, signal is at bottom, GND on top. What can I do?
Kind regards from Austria,
Bernd
2017-3-30
