Commodon
Flight distance : 347677 ft
Commodon Posted at 2017-3-20 05:22
If you have downloaded a map of the area to the DJI GO4 application where you intend to fly, then no. You do not need to have connectivity to the Internet when you fly.
If you have downloaded a map of the area to the DJI GO4 application where you intend to fly, then no. You do not need to have connectivity to the Internet when you fly. In fact, i specifically enable "Airplane Mode" on my nVidia Shield prior to launching DJI GO4.
With regards to downloading a map of the area before flying, do the following:
1. Enable wireless connectivity on the device.
2. Launch the DJI GO4 application on the device. Note the device is *not* connected to the RC.
3. Tap the three hotizonatal bars in the upper-right corner, then tap "Offline Map"
4. Select the Continent, Countries, State, etc. then tap the down arrow to the right. Repeat if necessary.
5. When finished, you should enable Airplane Mode on the device. |
