abdali.mehdi2
Hello,
I bought an ESC DJI Takyon Z318 in order to run a test with a BLDC motor. The motor is a PM1306 and I don't use a flight controller
So I used a PWM generator with variable duty cycle in order to generate a 5 Vpp signal with a frequency of 16kHz but the motor is not running.
However, I heard a bip when I connect the ESC with the motor and the battery but when I connect the BEC, it doesn't work.
Could you tell me how can I use this ESC ? (What kind of signal should I send ? What are the parameters ?)
I have also read the manual that furnished with the component and it says that the DJI Takyon Updater is required to connect the ESC with a computer and, to configure the different settings. But this updater is not include and when I research it in your store or an other website, I can not find it.
Where can I found this Updater in case if I need to change settings ?
Thank you,
