1.9.1.30 Firmware for Inspire 1 Series
123Next >
16044 119 2016-7-7
DJI-Paladin
Flight distance : 2408 ft
Overview:
1. All-in-One firmware version updated to v1.9.1.30.
2. DJI GO app iOS version updated to v2.8.4.
3. DJI GO app Android version updated to v2.8.2.
What’s New:
1. Fixed issue of temporary Vision Positioning System sensor error on rare occasions for some aircrafts.
Notes:
Aircraft version v1.9.1.30 and camera version v1.8.1.00 should be displayed in DJI GO. The version will only display correctly in DJI GO after connecting to the Internet when upgrade is complete.
The firmware can only be downgraded to v1.8.1.00 or later.
2016-7-7
Henry Mo-Yung
Flight distance : 11548839 ft
Thank you, Paladin for this notice.
And thank for the swift response DJI R&D Team took in the past 2 weeks diagnosing the issues and working out the solution.
Henry
2016-7-7
Wolfman
Flight distance : 405659 ft
The first person to test this one gets a prize!
2016-7-7
Wieg1
Many thanks to DJI Team.
2016-7-7
Rob W
Flight distance : 94390 ft
Sweden
Thank's, DJI! My aircraft have been grounded for the previous firmware (and also because of bad weather). I just flashed the new firmware and it seems to went well. Hope the weather now clears up!
[00008602][17 00][00] v1.1.0.6 -> v1.1.0.8 need upgrade.
[00065246][17 00][05] v1.1.0.8 -> v1.1.0.8
[00065484]Packet upgrade finish successfully.
2016-7-7
Henry Mo-Yung
Hi Paladin,
It seems the Aircraft Version and the Camera Version shown in the Inspire 1 Pro Release Notes are wrongly printed.
It printed:-
Camera version v1.9.1.30 and aircraft version v1.9.1.10  should be displayed in DJI GO .
In my DJI GO app, it shows:-
Inspire 1 Pro upgraded with Internal FW v1.09.01.21
2016-7-7
Henry Mo-Yung
Henry Mo-Yung Posted at 2016-7-7 21:17
Hi Paladin,
It seems the Aircraft Version and the Camera Version shown in the Inspire 1 Pro Release ...
Dear Paladin,
Here are the relevant extracts of the two log files:-
Upgraded with Internal FW v1.09.01.21 on 1 Jul 2016
[00006672]========== remo-con disconnect. boot(15) ============
[00006734]Packet [C:\WM610_FC550_FW_V01.09.01.21.bin] detected, card sn [0x919c2a2b].
[00006807]Packet upgrade start...
[00006869]Packet checking...
[00006937]Packet vlink 01.09.0121 <-> 01.08.0256.
[00007008]Record vlink 01.09.0110 <-> 01.08.0100 (flow = 0).
[00007163]Done.
[00007224]Version checking[1]...
[00009151][17 00][00] v1.1.0.6 -> v1.1.0.8 need upgrade.
[00009417]Done.
[00011498]Waiting for user confirm...
[00021564]Timeout, start upgrade automatically.
[00021687]Firmware upgrading[1]...
[00021767][17 00] Firmware upgrade start...
[00063206][17 00] Firmware upgrade finished successfully.
[00063267]Done.
[00063336]Version checking[2]...
[00066170][17 00][05] v1.1.0.8 -> v1.1.0.8
[00066550]Packet upgrade finish successfully.
Tried upgrading with FW v1.09.01.30 on 7 Jul 2016
[00006738]Packet [C:\WM610_FC550_FW_V01.09.01.30.bin] detected, card sn [0x919c2a2b].
[00006810]Packet upgrade start...
[00006886]Packet checking...
[00006948]Packet vlink 01.09.0130 <-> 01.08.0100.
[00007018]Record vlink 01.09.0121 <-> 01.08.0256 (flow = 0).
[00007088]Done.
[00007166]Version checking[1]...
[00009206][17 00][00] v1.1.0.8 -> v1.1.0.8
[00011488]Packet upgrade cancelled at version checking.
Grateful if you would confirm with DJI R&D colleagues that for my case no further upgrading is needed.
Thanks.
Henry
2016-7-7
shk747
Austria
mine shows after several "upgrades" 1.9.1.10+, 2.8.4 deleted / rebooted / reinstalled still same !
sure connected to the inet ;-)
p.s. tryed another ios device, same result ;-(
2016-7-7
job-h20-stegano
Flight distance : 779019 ft
Same here shk747, also shows 1.9.1.10+
On Android, latest version 2.8.2
Redownloaded update and inserted it, booted it up, turned it off. Looked at the log, it said firmware already up to date. So I assume it is updated to 1.9.1.30, I was also able to see the small update in the hidden log file which showed that the VPS received a small update.
But why does it not say 1.9.1.30 as aircraft version in the app?
2016-7-7
Rob W
Sweden
Hmmm... I've updated to 1.9.1.30 successfully, and I get:
Normal (latest firmware)
Aircraft: 1.9.1.10+  (note the +)
Camera: 1.9.1.10
I'm connected to the Internet.
2016-7-7
Nigpd
Flight distance : 597677 ft
Hmmmmm, here we go again
2016-7-7
GabeZ
Flight distance : 768448 ft
I'm wonder if this is exactly the same as the internal firmware.  I'm running the internal firmware and also see 1.9.1.10+.  I know it will take this update because I'd be going from 1.9.1.21 to 1.9.1.30.
2016-7-7
nilsblix
Flight distance : 23047543 ft
Norway
Rob W Posted at 2016-7-7 16:42
Probably something with the DJI servers makes it display 1.9.1.10 +
It happens from time to time on newly updated FW. No need to upgrade again if your .txt file says success. Just fly and eventually the + sign will disappear and display 1.9.1.30
2016-7-7
nivong
Flight distance : 2267251 ft
guys its normal it will update within 24 hours. give the slow chinees servers some rest
2016-7-7
DJI-Jamie
Flight distance : 112405 ft
Hi Paladin,
The release notes for the Inspire 1 Pro and Raw appear to have the correct camera firmware version indicated:
https://dl.djicdn.com/downloads/ ... Notes_en_160707.pdf
If you're referring to Paladin's post, he's referring to the Inspire 1 with the X3 camera. If you have the Inspire 1 Pro, then you appear to be fine.
2016-7-7
Henry Mo-Yung
DJI-Jamie Posted at 2016-7-8 05:55
The release notes for the Inspire 1 Pro and Raw appear to have the correct camera firmware version ...
Dear Jamie,
But for my Inspire 1 Pro, it shows Aircraft Version V1.9.1.30 in DJI GO, whilst the Release Notes state aircraft version v1.9.1.10 should be displayed after the upgrade.
Is there something wrong?
Henry
2016-7-7
DJI-Jamie
Henry Mo-Yung Posted at 2016-7-8 06:09
Dear Jamie,
But for my Inspire 1 Pro, it shows Aircraft Version V1.9.1.30 in DJI GO, whilst the Re ...
Perhaps a bit of dyslexia on behalf of those writing the release notes. We should have this rectified soon.
2016-7-7
Henry Mo-Yung
DJI-Jamie Posted at 2016-7-8 06:13
Perhaps a bit of dyslexia on behalf of those writing the release notes.  We should have th ...
Hi Jamie,
Thanks for confirming this.
Henry
2016-7-7
GabeZ
I just tried updating internal firmware 1.9.1.21 to 1.9.1.30 and it aborts.  It seems it's exactly the same firmware if I'm correct.
2016-7-7
DJI-Paladin
Henry Mo-Yung Posted at 2016-7-7 21:27
Dear Paladin,
The Log is OK.
2016-7-7
LICENSED PILOT
Flight distance : 692090 ft
nivong Posted at 2016-7-8 05:30
Another chinese fire drill...
2016-7-7
RichJ53
Flight distance : 1837356 ft
Thank you paladin and the DJI team
Rich
2016-7-7
Cabralkev
Flight distance : 1997861 ft
Is it worth updating? I've been hearing reports of battery failure with this firmware. Hopefully this is false information.
2016-7-7
Rob W
Sweden
nilsblix@gmail. Posted at 2016-7-7 23:27
It happens from time to time  ...
Yes, guess it's the servers again, thank's!
2016-7-7
RichJ53
Henry Mo-Yung Posted at 2016-7-7 06:27
Dear Paladin,
Henry
You need to downgrade your internal FW to 1.8 first. Then you can upgrade to the new FW 1.9.1.30  (you know why I know this )
That's why you are having trouble
Rich
2016-7-7
db050800
Flight distance : 2204462 ft
Wolfman Posted at 2016-7-7 11:56
I dont want the prize :0
2016-7-7
DJI-Paladin
nilsblix@gmail. Posted at 2016-7-8 05:27
The + doesn't influence normal operation of the drone. We are working on it. Thanks for your patience and understanding.
2016-7-7
OO-RAISER
Flight distance : 118323 ft
Indonesia
Seems DJI are listening to us and doing something
2016-7-8
Henry Mo-Yung
Thank you for confirming this, Paladin.
Henry
2016-7-8
Henry Mo-Yung
RichJ53 Posted at 2016-7-8 12:37
Henry
You need to downgrade your internal FW to 1.8 first. Then you can upgrade to the new FW 1.9 ...
Dear Rich,
Despite of the uncertainties in the upgrade process, I received positive confirmation email from DJI R&D Support;-
[Quote]
Hi Henry,
Your Inspire 1 has been upgraded successfully.​
Aircraft version should be 1.9.1.30 and camera version should be 1.9.1.10.
Inspire 1 Pro and Inspire 1 Raw release notes will be revised as soon as possible, thank your for pointing that out and sorry for the inconvenience.
H...... (of DJI)
Dear H...... (of DJI),
I notice that DJI on today officially announced FW v1.09.01.30 for the Inspire 1 Pro.
Before trying to upgrade, I found out from the About page in DJI GO App the Aircraft version was already showing Version 1.9.1.30 and Camera Version Version 1.9.1.10, which are different from the versions announced in the Inspire 1 Pro Release Notes, which stated "Camera version v1.9.1.30 and aircraft version v1.9.1.10  should be displayed in DJI GO”.
I tried to upgrade but the log file showed the following result:-
[00007088]Done.
[00007484][08 00][00] v2.14.9.42 -> v2.14.9.42
[00007549][01 00][00] v1.27.5134 -> v1.27.5134
[00007619][01 01][00] v1.27.5134 -> v1.27.5134
[00007692][01 04][00] v0.5.5085 -> v0.5.5085
[00007845][03 05][00] v34.1.0.5 -> v34.1.0.5
[00007966][03 06][00] v2.4.20.18 -> v2.4.20.18
[00008083][04 00][00] v1.29.0.92 -> v1.29.0.92
[00008205][05 00][00] v3.0.6.2 -> v3.0.6.2
[00008280][09 00][00] v3.0.0.4 -> v3.0.0.4
[00008406][11 00][00] v3.9.0.0 -> v3.9.0.0
[00008526][12 00][00] v1.11.0.0 -> v1.11.0.0
[00008646][12 01][00] v1.11.0.0 -> v1.11.0.0
[00008766][12 02][00] v1.11.0.0 -> v1.11.0.0
[00008886][12 03][00] v1.11.0.0 -> v1.11.0.0
[00009101][15 00][00] v1.1.2.0 -> v1.1.2.0
[00009326][17 01][00] v2.0.1.6 -> v2.0.1.6
[00009421][19 00][00] v1.0.8.96 -> v1.0.8.96
Would you confirm me that for my case no further upgrading is needed, please?
Thank you in advance.
Henry
[Unquote]
I think I will just fly it as-is.
Thank you.
Henry
2016-7-8
nilsblix
Norway
Have upgraded from 1.9.01.21 to 1.9.01.30 today - the upgrade went well (had to downgrade to 1.8 first but that was expected.)
I also swapped a CW motor that was running tight and hot - after swapping I had to upgrade again (probably to upgrade that motors esc)
Hope to get out flying this afternoon
2016-7-8
waxahachie tim
Flight distance : 47169 ft
Please help, My Inspire 1 is not seeing the 1.9.01.21 update. my iPad did update to 2.8.4. The controller is at 1.6 and the aircraft is at 1.8.1.00. The aircraft is ignoring the update file as is the remote. Ive tried with the controller off and on and on two different micro cards. Updates have never gone smoothy, but they always initiate.
Ideas anyone?
PS- there is no text file on the card
2016-7-8
nilsblix
Norway
nilsblix@gmail. Posted at 2016-7-8 17:57
Have upgraded from 1.9.01.21 to 1.9.01.30 today - the upgrade went well (had to downgrade to 1.8 fir ...
UPDATE
Out flying - no issues - promising
2016-7-8
AEROKAMERA
Flight distance : 2289429 ft
Poland
Today I flew out my 6 batts on last FW and GoApp, everything looks ok except old issues: camera hangs up and main controller data error-data recorder errors, on monday my I1P goes to support.
PS. Corrercted Inspire_1_Pro_Product_Release_Notes_en_160708 released
2016-7-8
GabeZ
RichJ53 Posted at 2016-7-7 21:37
Henry
Doh......I was hoping both versions were the same. I was trying to justify not downgrading and re-upgrading.  Looks like I need to do the SD card dance again
2016-7-8
Andy.Deveney
Flight distance : 640200 ft
Greetings,
    Updated with success this morning here in Southern California. After an IMU calibration, it flew great. no issues flying 5 batteries in a 2-hour period.
2016-7-8
waxahachie tim
I solved my problem. I redownloaded the file from the dpi site and everything is going well.
2016-7-8
Henry Mo-Yung
GabeZ Posted at 2016-7-9 04:54
Doh......I was hoping both versions were the same. I was trying to justify not downgrading and re- ...
Dear GabeZ,
DJI R&D staff replied me by email confirmed that my Inspire 1 Pro had been upgraded successfully - implying that the codes in both FW v1.9.1.21 and FW v1.9.1.30 are identical. My Inspire 1 Pro was showing version 1.9.1.30 in DJI GO App although it was only upgraded with the "Internal Firmware" v1.9.1.21.
You don't need to downgrade and upgrade if your aircraft is showing FW v1.9.1.30.
Henry
2016-7-8
RichJ53
GabeZ Posted at 2016-7-8 13:54
Sorry for the confusion, per Henry Mo-Yung you do not need to downgrade. Please disregard what I posted and see Henry's information above.
(I did not know that .21 and .30 were the same)
I did not know this information at the time I was changing my Inspire 1 V2 X3.
All good
Rich
2016-7-8
FictitiousPerso
Flight distance : 303356 ft
Austria
Updated DJI App inspire 1 + 3 Batterys this morning as normal not a single glitch. upgrade took about 2 minutes with each battery
2016-7-9
123Next >
