How to know gimbal is @ 90 degrees
1567 8 2016-7-9
bruce
Flight distance : 686916 ft
Since the gimbal allows me to point it above the horizontal, is there a way when the bird is in the air to set it to horizontal?  (I use this to see when I am at the top of something, and would hate to be below and then fly forward!)
Thanks
Bruce
2016-7-9
GabeZ
Flight distance : 768448 ft
Hi Bruce.  If you're talking about not knowing if the camera is exactly horizontal, because all the GO App shows you is a red dot off to the right with "tick marks", then there is no other way to determine it that I know of.  All you can do is move it until it somewhat lines up with the red dot.  At least with camera yaw, you can set your C2 button to reset it back to center.
2016-7-9
Aeromirage
Flight distance : 1778045 ft
I often do the same when I am unsure of clerances due to depth perception restrictions.
As GabeZ mentioned, the horizontal index mark is red. The others appear to be 10 degree incriments.
As long as the indicator is blue and covering the red mark you are within 3 degrees of horizontal.
+/- 3 of horizontal
+/- 3 of horizontal
Above / below
Above / below
2016-7-10
Tharg (from the
Flight distance : 120784 ft
Reset Gimbal position - Job done!
2016-7-10
bruce
Tharg (from the Posted at 2016-7-10 17:53
I could be wrong (usually am), but pretty sure reset gimbal just resets the YAW and not the PITCH.  Am I wrong???
2016-7-10
Tharg (from the
bruce@notalker. Posted at 2016-7-11 01:17
I could be wrong (usually am), but pretty sure reset gimbal just resets the YAW and not the PITCH. ...
You are wrong - it does both.
Oh no, hang on a minute....... I will have to check it now!
2016-7-11
DJI-Jamie
Flight distance : 112405 ft
Aeromirage Posted at 2016-7-11 00:39
As GabeZ me ...
Great screenshots.
2016-7-11
Aeromirage
Thanks!
And Gimbal reset only affects Yaw. Not pitch.
2016-7-11
GabeZ
We really need a way to reset pitch.... I wish I could set C2 to reset both  yaw and pitch.  I use c1 to switch to yaw.
2016-7-11
