ROSTOVisualFX
Flight distance : 123104 ft
Russia
De ja vu, блин. Broke my second OSMO, just like the first!
What is most surprising is that in the same location and in same scene...
Here is the place where I have failed two cameras OSMO (Please, see 360 VR Panorama): http://www.360cities.net/image/made-in-china#-538.84,-8.59,70.0
I arrived again to the country (suburban) in Bataysk, I leave the house in the yard and power on onto OSMO, standing on the threshold of the house under a metal roof and 50cm from working Wi-Fi router for window.
DJI OSMO turns on as it should, suspension work, connects to Wi-Fi phone, but video recording doesn't start, and videos of the phone are not transmitted! Then I noticed that both of the indicator is static green, the one on the left is more light green, the one on the right is more dark green.
I turned off the camera and took out the microphone, which did not use around the time of failure of the first OSMO, and perhaps that it the point. Turn on the camera again — everything now behaves exactly as the first, suspension is NOT working, and green and red indicators solid light!
Am sure 95% that it is likely in this microphone, I remember a few months ago accidentally severely bent the microphone when he was in monopod, and it is possible that the microphone something is damaged or shorted. Then insert this microphone in OSMO, it stopped working (I'm not sure what the microphone was inserted in the first OSMO, but most likely, because stereo microphone OLYMPUS I only have one, and other mutual causes of failure I see.
A picture of the suspect:
Now draw a parallels.
Both cameras probably got corrupted after contact with a possibly broken microphone (most probable version).
Both cameras probably got corrupted because of the inclusion near the strong radiation from Wi-Fi router (a little hard to believe).
Both cameras are probably corrupted due to the fact that I included them under the metal roof canopy and what not to do for quadcopters (except OSMO is also afraid of metal construction?).
Both cameras damage occurred in the same location, and I started thinking that this could lead to breakage. Except the microphone it could be metal construction or Wi-Fi router. Another comes to mind. I would like to hear comments DJI. And members of the forum.
95% I think the reason is most likely that the faulty microphone could lead to some glitch in OSMO.
5% could Wi-Fi router located 50 cm from OSMO at the moment when somehow something to broke?
0,0001% Metal roof can damage your compass? It's not a drone!
I experimented with the first OSMO, during a firmware downgrade to v1.4.1.80 the camera gimbal works and stabilizes, and even if you connect the phone, then there is an air-livevideo! However, to complete successfully the firmware fails, says to downgrade to this version it is impossible!
moiseev.sergey, do You used an external microphone with OSMO, and in particular at the time when OSMO is broken?
How long has this happened to You and how You were able to recover their OSMO?
Now I have two broken OSMO! So damn sad when I thought I'd do the shooting this week, and finally to test the Z-Axis.
DJI, tell me how resetnode module OSMO responsible for the microphone, or disable it altogether.
Please throw off the previous firmware which is possible downgrade from OSMO Firmware v1.6.2.10 2016-03-24.
Crashing at 99% is purely software in nature!
Сломалась моя вторая OSMO точно также как и первая!
Что самое удивительно, что та же локация и тоже место событий...
Вот место где у меня вышли из строя две камеры OSMO (360 Сферическая панорама места где у меня сломались сразу две OSMO с перерывом в 2 месяца): http://www.360cities.net/image/made-in-china#-538.84,-8.59,70.0
Приехал я снова загород в Батайск, выхожу из дома во двор и включаю OSMO, стоя на пороге дома под металлической крышей и в 50см от работающего Wi-Fi роутера за стеклом.
Включаю камеру тут находу она включается как и должна, подвес работает, подключается к Wi-Fi телефона, но запись видео не стартует, и видео на телефон не передаются! Тут я обратил внимание, что оба индикатора статично горят зелёным цветом, тот что слева более салатовый, тот что справа более тёмнозелёный.
Я выключил камеру и вынул микрофон, которым не пользовался примерно со времени поломки первой OSMO, и возможно именно в нём и дело. Включаю камеру снова — всё, теперь ведёт себя точно также как и первая, подвес НЕ работает, и горят зелёный и красный индикаторы!
Уверен на 95%, что дело скорее всего в этом микрофоне, я помню несколько месяцев назад случайно сильно согнул этот микрофон когда он был в моноподе, и неисключено что в микрофоне что-то повредилось или коротнулось. Затем вставив этот микрофон в OSMO, она перестала работать (я не уверен что микрофон был вставлен в первую OSMO, но скорее всего, поскольку stereo микрофон OLYMPUS у меня только один, и других общих причин поломки я не вижу).
Фотография микрофона, который мог явиться причиной поломки OSMO:
Итак проведём параллели.
Обе камеры вероятно испортились после контакта с вероятно испорченным микрофоном (наиболее вероятная из версий).
Обе камеры вероятно испортились из-за включения их вблизи сильного излучения от Wi-Fi роутера (мало верится).
Обе камеры вероятно испортились из-за того что я включал их под металлической крышей навеса, чего нельзя делать для квадрокоптеров (разве OSMO тоже боится металлоконструкций?).
У обоих камер поломка произошла в одной и той же локации, и я начал анализировать что в этом месте могло привести к поломке. Кроме микрофона это могли быть металлоконструкции или Wi-Fi роутер. Другое на ум не приходит. Хотелось бы услышать комментарии DJI. И форумчан.
95% я думаю что причина скорее всего в том, что неисправный микрофон мог привести какому-то программному сбою в OSMO.
5% мог ли Wi-Fi роутер находящийся в 50 см от OSMO в момент включения каким-то образом что-то вывести из строя?
0,0001% Металлическая крыша навеса разве может повредить компас? Это же не квадрокоптер!
moiseev.sergey, Вы использовали вообще внешний микрофон с OSMO, и в частности в момент когда OSMO сломалась? Как давно это случилось и как Вам удалось восстановить работу своего OSMO?
p.s.
Теперь у меня две поломанных OSMO! Блин так обидно, когда я думал провести такие съёмки на этой неделе и наконец-то протестировать Z-Axis.
DJI, подскажите как ресетнуть модуль OSMO отвечающий за микрофон, или отключить его вообще.
Пожалуйста скиньте предшествующую прошивку на которую возможен даунгрейд с OSMO Firmware v1.6.2.10 2016-03-24.
Я проводил эксперименты с первой OSMO, во время даунгрейда прошивки на v1.4.1.80 подвес камеры работает и стабилизирует, и даже если подключить телефон, то транслируется изображение! Однако завершить успешно прошивку не удается, говорит что понизить на эту версию нельзя!
Сбой на 99% носит чисто-программный характер!
