quint7
Flight distance : 518455 ft
I haven't tried any of the above yet, but I do have a video (from the bird) of basically what is happening. I did check the sticks on the flight record and it always shows when descending as if I'm pushing the stick to the right up to 28% as well, while descending always to the right. But I'm not pushing it at all that way. (I always understand there might be a little pressure.) I know sometimes you might do this unknowingly, but I've been testing this and I don't like going high cause it always spins coming down. So when I pull down anywhere from 30-100 percent, it is always showing 25% or so to the right. Here is the video. And I will try the things above and report as to what happens, but I am not unknowingly applying that much pressure to the right.
https://www.dropbox.com/s/7tm0sd ... Descending.mov?dl=0
Thanks,
Q |
