Question about IOC,turn-off failsafe on S1000-A2-LB2-Z15GH4(HD)
2175 4 2016-7-14
santorini95
Flight distance : 126896 ft
South Korea
i have two question.
Even if i read almost all thread, i cannot see reason.
My build is S1000+, Z15-GH4(HD), A2, LB2 -one remote controller. galaxy tab S2.
DJI go is recent version & all firmware is newest version.  gimbal control & shutter order & video is all well working.
1. when i turn off remote controller & I see "GPS-failsafe-Atti-failsafe-manual bar" picture  in A2 assistant software,  GPS indicator is not moved to failsafe section.
    In LB1 or futaba remote controller, i can adjust this via futaba channel mixing.
    but, in LB2 DJI GO app, where can i adjust this problem?
    or In LB2, regardless of this shift, when i turn off controller(no connection between drone and remote controller), failsafe is well working?
2. I cannot see  IOC icon in my galaxy tab S2.
    i found IOC  video for LB2 in youtube
    even if this guy use old version of LB2 in iOS, his screen show  IOC icon in upper center of pad
but, my screen is not show this icon.
so far, i did not outside flight test.  this icon become showed after A2 FC capture multiple gps ?
or, what setting i should do in A2 asssitant software or DJI go?
In my A2 assistant software, IOC checking was unmapped, failsafe checking was ON.  In P,A,F all mode, i cannot see this icon.otherwise, this icon only show in IOS, not in android ?
2016-7-14
DJI-Jamie
Flight distance : 112405 ft
Just to clarify, are you able to see your stick commands in the A2 software? Have you ensured that IOC is enabled on you A2?
2016-7-14
santorini95
South Korea
DJI-Jamie Posted at 2016-7-15 07:31
Just to clarify, are you able to see your stick commands in the A2 software? Have you ensured that I ...
In A2 software, all key is well working, AETRU, gear, go home key is well working.
but, In internet finding, users talk to unmap channel  associated IOC & uncheck IOC
I must check IOC (enable) & assign 1 channel with IOC in A2 assistant?
i will post my A2 command key  at home
Thank for your answer.
2016-7-14
santorini95
South Korea
I have done setup as next screen in A2 assistant
          a-2.jpg     e.jpg IOC was unchecked , IOC channel was not assigned
My Iphone6plus & Galaxy tab 8.2 is all new version DJIGo app.  A2 firmware also is newest version.
today, i done field test.
In GPS mode, when A2 FC capture GPS signal>14, i expect that IOC icon will appear, but it is not appeared.
I tried A2 setting changing - IOC check on, IOC channel  assign to CH8.
and then, P-GPS mode was fixed & changed to P-CL (courseLock).
maybe, It seemt to be correct that A2 IOC setting is unchecked
what can i do for see IOC icon (especially, i want homelock)?
2016-7-15
santorini95
South Korea
This problem is resolved via suppport.kr@dji.com
IOC problem was due to A2 FC version.
I used A2 assistant 1.8 & A2 firmware 2.6, but this was not newest version.
If u use A2 assistant 1.9 & A2 firmware 2.7, u also see IOC buttonr in Ipad & iphone6plus.
IOC icon is Lt side of ipad screen, is Rt side in Galaxy tab S2.
If u do setup  gear channel Ch5, go home channel CH6 in A2 software, irrespective of A2 assistant RC tab moving,  Turn off failsafe & button failsafe can be successful in field test.
2016-7-20
