Flame wheel f550 spinning out of control
2411 14 2016-7-14
user751e867ffe
For some reason, our drone has a very unstable yaw. We are using the Naza V2, and the weight is evenly aligned on a line of symmetry parallel and perpendicular to the Naza. In the controls, we tried editing the yaw settings all the way from 30% to 200%, but it didn't seem to make a difference to the spinning or the drift, both of which you can see in this video where we only adjust throttle.
https://www.dropbox.com/s/dlurr0kgwnjmu5o/VID_20160713_192852588.mp4?dl=0
2016-7-14
DJI-Jamie
Flight distance : 112405 ft
What RC are you using? Have you performed a RC calibration? Could you provide a screenshot of your RC settings in the Naza Assistant and the gains setting? Have you made sure your GPS mounting values are correct?
2016-7-15
user751e867ffe
DJI-Jamie Posted at 2016-7-15 14:47
What RC are you using? Have you performed a RC calibration? Could you provide a screenshot of your R ...
We are using the FlySky FS - T6, and we did the calibration where you move the sticks randomly around and you align the points to the center.
We are using a atti mode, so we haven't done any of the GPS work yet.
I will update soon with a picture of the Naza settings. The drone was spinning even when all of the settings were on default.
http://Sj
2016-7-17
DJI-Jamie
user751e867ffe Posted at 2016-7-18 13:14
We are using the FlySky FS - T6, and we did the calibration where you move the sticks randomly aro ...
Have you checked your motor configuration and ensured that each motor is spinning in the appropriate direction? Is the unit balanced? What stick mode are your using, or is it a custom stick configuration?
2016-7-18
user751e867ffe
DJI-Jamie Posted at 2016-7-19 02:12
Have you checked your motor configuration and ensured that each motor is spinning in the appropria ...
Our propellers alternate color and don't fall off, and they spin in the correct direction. Our sticks mode is North American, and I believe that it's still the default on the remote which is 1.
Our drone looks fairly symmetrical, how can we check if it's balanced?
2016-7-18
user751e867ffe
user751e867ffe Posted at 2016-7-19 13:09
Our propellers alternate color and don't fall off, and they spin in the correct direction. Our sti ...
Here are the Naza settings.
2016-7-18
DJI-Jamie
user751e867ffe Posted at 2016-7-19 13:27
You would make sure that it's balanced by holding the unit up by 2 opposing axis and see if it does not tip over to one side. In regards to your Naza settings, I do not see any stick inputs from the RC, do you have the RC on? Could you provide a screenshot of the Basic > RC section?
2016-7-19
jim.chisholm
Flight distance : 152352 ft
user751e867ffe Posted at 2016-7-19 02:27
Do you really mean +12 for the Z axis?
This would mean that the GPS/compass is 12cm *below* the COG.
If your GPS/compass is on top of your 550 the Z axis should be negative.
(Mine is set at -11, it's 11 cm above the COG and mounted on the top deck).
2016-7-21
lasuncion
Guam
Hello, what is the recommended gains for the F550 with Zenmuse H3-3D and GoPro Hero 3+? Also, I'm planning on using 14.8V 4000mah 30C battery.
Appreciate any help from you guys.
Thanks!
2016-7-24
DJI-Jamie
lasuncion Posted at 2016-7-25 09:34
Hello, what is the recommended gains for the F550 with Zenmuse H3-3D and GoPro Hero 3+? Also, I'm pl ...
What flight controller are you using?
2016-7-25
DJI-Jamie
Do you still need assistance?
2016-7-25
user751e867ffe
DJI-Jamie Posted at 2016-7-26 05:43
Yes, we still need assistance. We edited the Z  to -11 as the previous post suggested, and we moved the LiPo battery so that the Drone is balanced on all the axes. We redid the compass calibration exactly where we were flying it, but it still spins out of control.
2016-7-26
user751e867ffe
user751e867ffe Posted at 2016-7-26 19:31
Yes, we still need assistance. We edited the Z  to -11 as the previous post suggested, and we move ...
It turns out that we flipped clockwise and counterclockwise motors, and so that fixed the yaw problem. However, the Drone still drifts a bit when we fly it.
2016-7-26
DJI-Jamie
user751e867ffe Posted at 2016-7-27 12:54
It turns out that we flipped clockwise and counterclockwise motors, and so that fixed the yaw prob ...
Good to hear the spinning stopped. Regarding the drifting, is it a toilet bowl effect type of drift or does the unit move in various directions?
2016-7-27
DJI-Jamie
DJI-Jamie Posted at 2016-7-28 02:06
Good to hear the spinning stopped. Regarding the drifting, is it a toilet bowl effect type of drif ...
Do you still need help?
2016-8-1
