skipilot1
Flight distance : 1557398 ft
You will always have some moire due to the camera chip itself. You just need to minimize it as much as possible.
If you are using the ND8 in bright sun and only partially overcast then you need to start using a ND16. A polarizer can help somewhat over roads, water, light colored buildings and anything else that is highly reflective.
Set your white balance to D-Log and your sharpness to -2, contrast -3, and saturation to -2. Also, your shutter speed should be no more than twice your fps. If you are recording at 30 fps your shutter speed should be no more than 60.
Don' worry about the settings as you can quickly and easily adjust them in your post production software. |
