Matt-and-Riley
Flight distance : 324442 ft
Not sure I like the extension rod very much. You have to screw the entire Osmo to the thin end of it and when fully extended it's quite heavy and wobbles around quite a bit. (Even worse if you try adding the z-axis as well). It also means you have to control everything through the app, you can't use the trigger, joystick or buttons on the handle. I find it much more accurate to use the joystick rather than sweaty fingers on the phone.
Shame it couldn't be a bit more like the z-axis and fit between the body and camera head. Then I'd still be able to use the Osmo handle controls and would be lifting only the camera providing a more stable and easy shot.
But I guess I'm stuck with lofting the camera, handle, battery and gubbings above my head
Come on DJI, you have some great ideas and products, but you're not thinking about the detail and how it will be used.
