Connecting accessories
1153 0 2016-7-23
rodjmoore
For the Matrice 600, what is used to connect an accessory to the bottom of the drone that is not a gimbal? I'm designing an accessory and would like to determine what dimensions are used and the easiest way to physically attach the device to the drone. Would it be the expansion mounting kit? If so is there instruction guide for that? Also would the Can1 extension port be the best way to connect power to the accessory? Is there specs for the Can1 port for voltage etc?
Thanks,
Rod
2016-7-23
