Problems with DJI Remote Focus and the OSMO X5
1682 10 2016-7-26
mazurlazer
Flight distance : 2303 ft
Hello,
I've run into a problem with my OSMO X5 and DJI Remote Focus setup that I can't seem to fix. The focus (with the adapter cable) connects easily to the OSMO and works as it should. The problem that I have is that whenever I pull focus on the remote, the X5 automatically resorts to the lowest apeture possible for the lens I'm using (f1.7). This is not a mixup with the apeture controls that are possible with the remote (this works just fine). It is only after I've set my desired apeture and then turn the focus wheel in any direction. Yes, I have tried reconnecting everything and have restarted the reomote, the app, and the handle. Nothing seems to fix this.
Is this just a glitch? Has anyone else had this problem? Please help!
2016-7-26
dopeytree
Flight distance : 6716467 ft
Yes I feel you pain I just almost ruined a commission because of this bug. It wasn't in the previous firmware! See my post here: http://forum.dji.com/thread-59211-1-1.html
A slight workabout I have found the focus remote works if you have the camera set in shutter priority mode.
Hopefully DJI can get out a fix ASAP.
2016-7-26
mazurlazer
dopeytree Posted at 2016-7-26 16:05
Yes I feel you pain I just almost ruined a commission because of this bug. It wasn't in the previous ...
Okay thanks for the reply. DJI? Anything from the bots on this site?
2016-7-26
steven.dieveney
Flight distance : 26 ft
Same problem here. Very frustrating!!!!! I let DJI know and have gotten zero response. Hopefully they fix it very soon!!!
2016-7-26
mazurlazer
steven.dieveney Posted at 2016-7-26 20:56
Same problem here. Very frustrating!!!!! I let DJI know and have gotten zero response. Hopefully the ...
Terrific! Yet another $1,000 paper weight. At a certain point it becomes my own damn fault for continuing to patronize this company...
2016-7-26
masonthoward
I have the same issue. I found that on the remote you have to switch over to the aperture setting and set that and then switch back to the focus setting and your focus will work with that aperture setting locked in.
2016-7-26
DJI-H.C
Flight distance : 13602 ft
We're sorry about this. The engineers are currently aware of this issue and are working on it.
2016-7-26
gilbertchan
Flight distance : 373681 ft
Singapore
Same problem here. thought i got a faulty unit. hopefully its just a bug.
2016-8-4
Luke_Boney
Flight distance : 1305010 ft
Also having this issue, just wanted to keep the ball rolling.
2016-8-5
chubauk
Luke_Boney@yaho Posted at 2016-8-5 15:12
And me too!!!!
2016-8-5
pistolstamen
Such a bummer. Shutter priority it is.
2016-8-24
