dennismurry08
Flight distance : 5948264 ft
Well sorry, I'm west coast...but by your pictures (wish it was video) I would ask that you check a couple things. Start it up and idle...then move your control stick forward a little...see if the 900 tilts slightly forward. Then do backward...same thing...dont have the throttle up enough where it will tip over....I have seen people have their controls reversed after an upgrade...meaning you think your pushing forward but because the controls are reversed it goes backward...then the more forward you push the more backward it goes. If you do this and find out thats the problem you can go into your assistant and either check or uncheck the "REV" box. In other words if its checked then uncheck it. But word of caution, you should ALWAYS check what I just said before any takeoff...forward, back, left, right...with just enought throttle to see the 900 tilt, not any more...let me know |
