alexchatham
I have built a custom aircraft for filming and want to set it up with an X5. So far, I have and X5 on a Matrice 600 gimbal mount hooked up to the Light Bridge 2 and A3 flight controller. Its basically a Matrice 600 without the wings. When I power up the Gimbal, it spins and goes into place for a few seconds, then goes flaccid and beeps. Has anyone done a similar custom set up with success?
I should note that video preview streams to my phone! I cycle it the power to everything 5 times and every time video worked. However that is about it.
The DJI GO app says that LB2 firmware needs a critical update, the gimbal does not receive any MC Signal and I need to check pins on some cable..bla,bla..
The gimal remains crooked at 45 degrees :/ but the autofocus works when you touch some areas on the screen!
Weird, right? Is the gimabl underpowered?
