Announcement of Zenmuse H4-3D
25651 27 2015-1-27
DJI-CS
China
Announcementof Zenmuse H4-3D
H4-3D 3-AXISSTABILIZATION
Forget shaky, unusable aerial footage. Fly your GoPro Hero4 Black withthis gimbal and capture smooth, stable content like never before. Your camerais stabilized to prevent unwanted roll, tilt, and pan motions, giving you theconfidence to fly difficult maneuvers and get the shots you want.
Features
EASY TO SETUP
Simply mount the gimbal to your flight platform, attach your camera, andyou’re ready to fly. Your H4-3D gimbal is calibrated and pre-programmed to workright out of the box.
CROSS-PLATFORMCOMPATIBILITY
Whether you’re flying a DJI Phantom 2 or other platform, the H4-3D iscompatible. Use a DJI A2, WooKong-M, or NAZA-M flight controller on any FlameWheel for the highest level of customization.*
*The H4-3D gimbal comes customized for the DJI Phantom 2. If you want touse it with the DJI Flame Wheel or other platform with DJI flight controllers,the independent GCU module is required. Note NAZA-M LITE is not supported, anda NAZA-M V2 PMU must be used if using a NAZA-M V1 flight controller.
INDEPENDENTIMU
No gimbal can stabilize a camera without tracking how your aircraft isbeing tilted and moved in real time. That’s why the H4-3D has its ownintegrated Inertial Measurement Unit (IMU) constantly collecting preciseinformation and feeding it to the gimbal. This IMU tells the gimbal exactly howyou’re moving in the sky and how much countering force is required to keep yourcamera still, every millisecond.
SMALL, LIGHTWEIGHT, DURABLE
Engineered to add a minimal amount of payload weight to your flightplatform, the H4-3D maximizes flight time without sacrificing quality. Bycombining a compact yet high strength aluminum body with a high level ofdurability, you fly knowing that your camera is secure.
DOWNLOADABLE UPDATES
DJI is constantly working to improve your experience and help you getthe most out of your systems. Free firmware updates ensure you are at theforefront of this technology, and are available for your H4-3D at the click ofa mouse.
OPTIONAL GCU MODULE
The Zenmuse H4-3D gimbal is customized for the DJI Phantom 2 and doesnot include the optional Gimbal Control Unit (GCU). If you want to use it withother DJI flight controllers and flight platforms, the independent GCU moduleis required and sold separately.
Specifications
General
Features
(1) Zenmuse technology
(2) 3-axis gimbal
(3) High precision brushless servo control
(4) Built-in IMU module
(5) Light-weight
(6) A2, WKM, Naza-M, Naza-M V2 ,Phantom 2 support
(7) GoPro Hero4 Black  support
Peripheral
Supported Camera: GoPro Hero4 Black
GCU Input Power: 3S~6S LiPo(12V~26V)
PC Assistant Software System Requirement: Windows XP SP3; Windows 7;  Windows 8
Mechanical & Electrical
Working Current Static current: 400mA (@12V); Dynamic  current: 600mA (@12V)
Gimbal Input Power: 3S~6S(12V ~26V)
Operating Temperature: -10°C ~ 50°C
Gimbal Weight: 168g (camera excluded)
Gimbal Dimensions (With Damping Unit): 103mm X 92mm X 80mm
GCU Weight: 22g
GCU Dimension: 42 mm X 32 mm X 9.3 mm
Performance
Angular Vibration Range: Pitch/Roll:±0.02°, Yaw: ±0.03°
Maximum Rotation Speed: Tilt axis: ±130°/s
Controlled Rotation Range: Tilt axis control: -130° to +45°
Regulatory Approvals
FCC(USA):  Yes       CE(EU): Yes    RoHS(EU): Yes
H4-3D and H3-3D Comparison
H4-3D supports GoPro4 Black.
H3-3D supports GoPro3, GoPro3+ Black and Sliver.
2015-1-27
ghostmaster
Portugal
Same weight on the gimbal leads me to think its the exact same thing as the H3-3D, no bigger motors, not any new improvements over the old H3-3D, so why do we need to pay more?
2015-1-27
borlox
Why won't the H4-3d work with the Hero4 Silver? How much will the GCU cost?
2015-1-27
ghostmaster
Portugal
borlox Posted at 2015-1-28 03:35
160$... Its a rip-off...
2015-1-27
robertdreeszen.
Flight distance : 11150600 ft
Will the H4-3D w/GP4 Black feed video via the usb cable to the CGU then to IOSDII or miniosd? Does this make the GoPro 4 Silver unsupported on either H3-3D or H4-3D?
2015-1-28
ghostmaster
Portugal
robertdreeszen. Posted at 2015-1-28 16:51
Will the H4-3D w/GP4 Black feed video via the usb cable to the CGU then to IOSDII or miniosd? Does t ...
Its the same system used by the H3-3D and the Hero 4 Silver is supported by the H3-3D without any problem, just use the last H3-3D version with USB ribbon cable on the side.
2015-1-28
ianwood
Flight distance : 5236 ft
ghostmaster Posted at 2015-1-27 23:56
Same weight on the gimbal leads me to think its the exact same thing as the H3-3D, no bigger motors, ...
Agreed. Configuration change most likely. Probably apply the H4-3D firmware to an H3-3D and presto magico, your gimbal now works for the H4B.
2015-1-28
robertdreeszen.
ghostmaster:
  According to the DJI doc only a Gopro 3 silver is supported by H3-3D.   I have a H3-3D  and my GoPro 4 Silver will not feed video via the usb ribbon cable on the side to the GCU  and IOSDII.
2015-1-28
ghostmaster
Portugal
robertdreeszen. Posted at 2015-1-29 15:01
ghostmaster:
  According to the DJI doc only a Gopro 3 silver is supported by H3-3D.   I have a H3-3 ...
Something is very wrong with your camera or gimbal, the H3-3D with USB cable works fine for both Hero 4 Silver and Hero 4 Black outputing video for FPV, the only problem with the Hero 4 Black is the weight, it has 12g more than the Hero 3+ Silver and that causes the gimbal to became unbalanced.
2015-1-29
robertdreeszen.
Many instances on the forums where video out from usb cable on GP4  Silver or Black to H3-3D to GCU to IOSDII or miniosd doesn't work but can see OSD data.  Agree that balance is an easily fixed issue but have yet to see someone show me AV2 output from an IOSDII thru a H3-3D/GoPro4 silver. Gimbal works fine if I unplug usb cable from gimbal and run GoPro on its own battery power.  That may be a definition of working fine but my expectation was video out thru other DJI components like IOSDII.
2015-1-30
ghostmaster
Portugal
Good luck trying to sell the same thing as the H3-3D but with higher price...
2015-2-12
haski
Poland
ghostmaster Posted at 2015-2-12 21:45
https://www.youtube.c ...
thx 4 review
2015-2-12
tsoi_vv.mail
Thailand
H4-3D complete NAZA V2, module GPU H-3D not control the speed of inclination (tilt). Tilt speed camera as big as in previous versions H3-3D, H3-2D. Are provided for addressing this issue. Announced the release of a new model this problem H4-3D promised to solve.
2015-3-24
ahed.amt
United Arab Emirates
Hi Guys,
I have H4-3D I want to install on F550! is it possible to use GCU for H3-3D on the H4-3D?
Kindly I need urgent respond before I try
2015-4-16
Panykoizi
DJI - CS,
I'm a proud owner of a DJI Phantom and I use this forum all the time I'm doing my dissertation on user communities and would love to have a chat with a DJI representative? It would really help with my dissertation
2015-5-4
islandflyer
Guam
Panykoizi Posted at 2015-5-4 18:59
DJI - CS,
I'm a proud owner of a DJI Phantom and I use this forum all the time  I'm doing my diss ...
How'd that chat with DJI work out?
2015-6-11
eric.rouch
hello
I have a phantom v1.1.1 with naza Mv2, PMU v2, IOSD Mini, GCU Zenmuse H3-3D, Gimbal Zenmuse H3-3D, and Gopro HERO 4 Silver;
I can't control the speed of inclination (tilt) of the zenmuse, Why??
Please
2015-6-14
eric.rouch
hello I have a phantom V1.1.1 with naza Mv2, PMU V2, IOSD Mini, GCU Zenmuse h3-3d V2, and Gimbal ZENMUSE H3-3D with Gopro HEro4 Silver.
I can't control the speed of inclination (tilt) of the Gimbal H3-3D Why?
Please
2015-6-14
SimplePanda
Flight distance : 1719062 ft
ahed.amt Posted at 2015-4-16 16:44
Hi Guys,
It probably will work.
The H3-2D controller would happily drive an H3-3D (I installed an H3-3D gimbal onto a Phantom 1 with a Phantom Upgrade Board (H3-2D controller) and it was fine.
I've also seen guys who installed the H3-3D onto F550's using the GCU modules from H3-2D's because in the early days you could only really get H3-3D's for the Phantom 2 (integrated gimbal controller already).
So given that the H3-4D seems to just be an H3-3D with different gains applied and a notch removed from the different button position... I'm sure it'll probably work fine.
2015-7-6
christyindublin
hi , i just got a dji2 and 4H-3D gimbal but the gimbal not working right as when i
try control it with the wheel it only works now and then
can i update the unit on my macbook pro ? thanks for any help
2015-8-12
DJI Candice
christyindublin Posted at 2015-8-13 00:41
try control it w ...
Hi christyindublin, yes, you can. Connect the Phantom to Phantom assistant, you can upgrade the drone and gimbal's firmware. Regarding your problem, please try calibrating the RC.
2015-8-13
christyindublin
Thanks Candice i did as you said and all working now ,
2015-8-26
DJI-Dave
Yep, firmware updates can fix a lot of problems.
2015-10-8
jmesq32
Portugal
eric.rouch@alic Posted at 2015-6-14 09:23
hello I have a phantom V1.1.1 with naza Mv2, PMU V2, IOSD Mini, GCU Zenmuse h3-3d V2, and Gimbal ZEN ...
Please update fw on your gimbal
2015-12-24
noaches232
Is it still for sale?
I hope it is...
2016-1-30
noaches232
If only this was installable on the Matrice 100...
2016-5-12
noaches232
Then you could have one camera (GoPro) for FPV while another operator used a X5 or X5R.
2016-5-12
igorshiling
Russia
How can I calibrate Zenmuse H4-3D. The horizon is falling.
2018-10-9
