Help.....Indicator SYSTEM Signal on wifi extendr not blink Phantom 2 vision
2047 3 2015-1-27
nguyendung1307.
Vietnam
         Now i use phantom2 vision. I still connect to wifi between mobile (SS3) with phantom  ok. But i open DJI app in mobile not show anything. I change a new mobile is not work. So i ontinute check setting on DJI app, click to bind see alarm: Wifi repeater connection failed.
So i check Power wifi extender signal is strong (green), but SYSTEM is off (not blink is usual). I tried restart wifi extender but it the same.
have you favor to solve the problem?
Thanks for support!
2015-1-27
冬瑞
China
When the system light is off,it means your WIFI network works abnormal.
Could you try to rebinding your range extender as the picture shows?
If still failed,the range extender may be broken somehow,  we suggest you went to your local dealer for help. QQ图片20150128175133.jpg
2015-1-28
nguyendung1307.
Vietnam
Thanks a lot. So i follow step you say. But it not ok. So may be broken as you say.
2015-1-28
Gerry1124
nguyendung1307. Posted at 2015-1-28 23:54
step 1
push reset button on the range extender, might take 30 seconds for system to flash green.
let me know what you get
2015-1-28
