MD_Icarus
As mentioned above, it can occur and I have tested this on my P4 by bringing it straight down and as the "legs" start to wobble, then slow it down and move forward.
I never bring it straight down from high altitude, especially if there is cross wind, because if it starts going into VRS, and then a strong cross wind hits it, then the results are un-predictable (and I would not want to find out). I usually start descending further out and I use both sticks to first bring it down and then land it; (I usually grab it though, I do not like to land it on sand, etc).
I also wonder what would happen is someone makes a mistake when the use a third party application to upload a mission, but they make a mistake with altitude ranges. For example, let's say one point is set to 300' and the next one by mistake is set to 30'. If the next location set to 30' is close to the prior location (300'), I am not sure what would happen. I have seen videos of P4 dropping, and I always wondered if it's such operator error?
I also wonder if there are safeguards in the firmware, which will not allow an altitude gradient, which the P4 can not handle?
