daver/m
Flight distance : 234590 ft
1. Check the Balance of the props .
2. The props are not seating properly to the motors when tightened, this is bad if true as they need to seat , my p1 and p2 style props do seat very nicely wether nutted or spin on .
Also the inspire uses motor braking !
3. The transforming combo landing gear motor mount arms ? Cool idea but seems to me that mechanical design will be taking a lot of punishment and abuse the more it's used the looser it will become ? hard landings or just bouncing round in its case during travel etc.
solid arms for mounting the motors and a separate landing gear setup could have been better , I'm thinking bird crashes hitting its gear hard ... And now you've got the motor booms , and the linked landing gear mechanism etc all taking the hit .... $$$$. Ouch !
My version , solid motor mount booms , seperate retractable landing gear , Get rid of the optical flow indoor sensor cam and replace it with a stationary FPV cam for the pilot ! Duh .
