rmaxwell.email
Flight distance : 698661 ft
Hi hakan,
I am a retired electronics engineer and I will try to explain how the system works. It uses what is called 2.4 Ghz spread spectrum. (Note the video downlink uses 5.8Ghz) Each transmitter manufactured for radio control in the world is given a unique digital code for each transmitter. When you "bind" a transmitter to the receiver in the Inspire One it establishes a connection between the two units that is unique. This way no other transmitter will interfere with the control of your unit. Spektrum radio gear claims they have flown 100 radio controlled aircraft at the same site without any interference. Note that the limit of three units probably applies to the video downlink from the camera, in as much as it takes far more radio bandwidth to send the video down then to send the control signals up to the unit.
So...I would suggest that if you have many units flying at one location, you will get interference with the video downlink far sooner than interference with the control of your Inspire One.
Hope this helps,
Ray |
