Ronin and ursa mini
5948 9 2016-8-17
abdou.yo
Algeria
I'am about to buy the original ronin and the ursa mini but i have a few question(i looked in the forum in the old topics but i did not found all the answers that i need).
Maybe it's a stupid question but...the plate provided with the original ronin is it compatible with ursa mini or i should buy a specefic one to fix my camera on the ronin ? and i want to add a folow focus to the rig and a monitor( for the monitor i found the answer).
Thanks in advance for your answers
2016-8-17
valealvarez.s96
Argentina
Yes, the plate is universal to all cameras like Red, alexa, canon, dslr, sonys etc, 1/4 and 3/8 screws. And yes you can mount motors for iris, focus and zoom with the rods the ronin come, you have 2 d-tap output for accesories
2016-8-17
abdou.yo
Algeria
valealvarez.s96 Posted at 2016-8-17 15:42
Yes, the plate is universal to all cameras like Red, alexa, canon, dslr, sonys etc, 1/4 and 3/8 scre ...
Okay thank you for the informations
2016-8-17
DJI-Jamie
Flight distance : 112405 ft
The plate should be fine. The Ursa Mini is a larger camera, so you may need to put the Yaw and Roll extension arms in order to fit. Any room for extra accessories you want to add would be based on the type of lens you use with it. You would not be able to use the side grip as well.
2016-8-17
alexander.sucke
Would the URSA-Mini fit on an M600/Ronin-MX?
2016-8-17
DJI-Jamie
alexander.sucke Posted at 2016-8-18 03:45
That camera would be too large for the Ronin MX, as it is the same size as the Ronin M.
2016-8-18
jmboto
Flight distance : 6781407 ft
Portugal
alexander.sucke Posted at 2016-8-17 20:45
The Ursa mini fits the Ronin MX. Extensions rod and extra gimbal battery. Mine works very well with a pancake lens. Canon 24 mm
2016-8-19
alexander.sucke
Just found a video for setting up a Ronin-M with the URSA mini:
So if the M and the MX give the same clearance for the camera it should be fine.
Lets See next, if the Start/Stop with the BMCC Lan-C cable will work with the URSA mini.
Thanks!
2016-8-21
fans103dba15
Ukraine
Hello! Tell please! How can i change settings of mini ursa installed on dji ronin. For example WB or shutterangle. This settings can be changed using buttons under the viewfinder. But when ursa installed on Ronin, view finder can be opened fully
2017-4-3
YahyaWalijee
Flight distance : 13927 ft
Kenya
jmboto Posted at 2016-8-19 16:07
Hi have been looking for someone who has used the Ursa mini with the Ronin MX. Where can I get the extension rods to fit the Ursa mini on the MX.
2017-5-28
