Camera not facing forward points slightly to the left??
6515 31 2016-8-17
PommyDownUnder
Hi Guys,
Is there a way of resetting the camera so that it faces forward, it is at a slight angle to the left, Its been like this since i bought it but I just put up with it,
the trouble comes when your trying to fly in a strait line say down a road and it just wonders off becase the camera is faceing where i want to go, but the Drone isn't.
HELP!! Please anyone. Thanks Glyn.
2016-8-17
TechReviews
Flight distance : 99852 ft
HI
have you tried a gimbal calibration ? should sort any issues with camera.
2016-8-17
PommyDownUnder
TechReviews Posted at 2016-8-18 08:09
HI
Yes, I tried the gimbal calibration a couple of times, but still the same :-(
2016-8-17
TechReviews
PommyDownUnder Posted at 2016-8-18 02:57
OK try the imu calibration then the gimbal calibration straight after
2016-8-17
AG0N-Gary
Flight distance : 700846 ft
It likely won't help.  There are several of us with "left facing cameras".  Trying to re-aim the arm to make up for it is difficult because of the flat side of the shaft, but it does help.  Still working on mine.
2016-8-17
DJI-Paladin
Flight distance : 2408 ft
Hello PommyDownUnder, which drone do you use? Do the IMU and gimbal calibration help?
2016-8-17
PommyDownUnder
AG0N-Gary Posted at 2016-8-18 12:57
It likely won't help.  There are several of us with "left facing cameras".  Trying to re-aim the arm ...
Thanks, I will have to put my thinking cap on, it is very annoying, once you realize what the problem is.
2016-8-18
PommyDownUnder
TechReviews Posted at 2016-8-18 12:34
Thanks, I will give it a go and see if that works, fingers Crossed.
2016-8-18
PommyDownUnder
DJI-Paladin Posted at 2016-8-18 13:56
Thanks for your advice, I will give that a go, I will report back here after I have done it. Oh PH3 pro
2016-8-18
n.shtykov
Flight distance : 71778 ft
Russia
PommyDownUnder Posted at 2016-8-18 16:14
Thanks for your advice, I will give that a go, I will report back here after I have done it. Oh PH3 ...
Have the same problem but camera looks a little to the right
2016-8-18
n.shtykov
Russia
2016-8-18
n.shtykov
Russia
Have the same but camera looks a little bit right
2016-8-18
n.shtykov
Russia
Just tried I use calibration and straight after that gimbal calibration... I think this hepl, well now I can't see that camera looks right, maybe 1-2 degrees
2016-8-18
TechReviews
PommyDownUnder Posted at 2016-8-18 04:14
no problem, let me know how you get on,if it doesn't work we can look into other possible soloutions
2016-8-18
maxxyz
Russia
Hello! There is a problem with the camera gimbal on my quadcopter Phantom 3 Advanced. This is not a problem of the horizon. If you look on top of the quadcopter, you can see that the camera is turned to the left at an angle of about 5-10 degrees. This makes it difficult to make a video. I can send a photo of this problem. Question: Is it permissible deviation of the camera? If so, at what angle? And if not, how to solve a problem. P.S.: The quadcopter is not crashes! All calibrations were made according to the instructions!!!
Gimbal problem
Gimbal problem
2016-8-18
AG0N-Gary
PommyDownUnder Posted at 2016-8-18 03:11
Thanks, I will have to put my thinking cap on, it is very annoying, once you realize what the prob ...
Yes it is, especially when you try to FPV "straight ahead".  Also, notice that the left front arm dips into the image on some stops, etc.
2016-8-18
PommyDownUnder
Hi, I did the IMU and then the Gimbal Calibration and its still the same, another chap has put a picture on this tread, mine is the same as that one.
2016-8-18
PommyDownUnder
maxxyz Posted at 2016-8-19 00:09
Hello! There is a problem with the camera gimbal on my quadcopter Phantom 3 Advanced. This is not a  ...
I feel for you mate mine is exactly the same as yours
2016-8-18
DJI-Paladin
PommyDownUnder Posted at 2016-8-19 13:17
Hi, I did the IMU and then the Gimbal Calibration and its still the same, another chap has put a p ...
Which drone are you using,  P3 or P4?
2016-8-18
maxxyz
Russia
maxxyz Posted at 2016-8-18 22:09
DJI-Paladin can you tell me about this, please?
2016-8-19
DJI-Paladin
maxxyz Posted at 2016-8-20 14:44
If IMU calibration and gimbal calibration don't help,please contact support@dji.com and send it in.
2016-8-19
PommyDownUnder
maxxyz Posted at 2016-8-20 16:44
I've heard a lot of scary stories of people sending there drone in to be repaired, not only does it take many weeks before you see it again, I keep seeing that they have come back and they have still not fixed the issue, or have even more problems??
I think I will find my own solution even if i have to modify the shaft where the camera rotates.
You would think there would be a setting in the app like the one that adjusts the Horizon???????????????
That would be too simple lol. Good luck everyone with this issue.
2016-8-20
maxxyz
Russia
PommyDownUnder Posted at 2016-8-21 06:34
I've heard a lot of scary stories of people sending there drone in to be repaired, not only does i ...
Thanks a lot )))
2016-8-21
garylok
Flight distance : 27690 ft
I have the P4 and only recently my camera is facing slightly left (horizontally, same as the photo posted earlier in the thread). I have already tried to calibrate IMU and then the gimbal but still facing left.
As soon as i turn the drone off, the camera drops and lands straight but cant set it so it looks forward.
Can I get some help on this one please?
2017-3-11
FlyingCircles
Flight distance : 76309 ft
There are many folks having this issue and just live with it, which is not right.  DJI should be able to create a setting for this but choose not to for whatever reason.   See this post from last year, it talks about how and why the problem exist and also a solution.
http://forum.dji.com/forum.php?m ... D369%26typeid%3D369
2017-3-13
FlyingCircles
We should keep this post active so DJI can see how many have the same problem.
2017-3-15
hughh
Yes I have this same problem with Inspire 1. Any solutions DJI?
2017-4-10
aalex
Flight distance : 13845 ft
Same problem camera looking to the left P3P.
2017-6-26
TCDrone
Flight distance : 2710732 ft
Hey guys. Yeah I've got the same problem on my P3A.  Mine points slightly to the left also.  I thought mine was,due to a crash I had but apparently not.  Any help on this,issue from DJI?????????????
2017-6-26
ahooper84
Flight distance : 192201 ft
Same here. 1 week old Phantom 3 Standard.
2017-7-14
Blakejohnsoncsr
I'm having the same issue with my P4Pro..... This is super frustrating.  I truly feel that my P3Pro was a more stable bird to be honest.  Video quality is amazing on the P4Pro but i don't feel like I'm in control while flying, feels like I'm drifting out to the right and back to the left.  Queue the DJI support person.  Hi Blake please try calibrating the IMU and compass.  Then try calibrating the gimbal.  Hoping for your cooperation and understanding....
2017-9-27
fansa0c5e2e3
Flight distance : 82956 ft
I also have this problem pointing left of center. Is there an older app or firmware that has Gimbal Yaw adjustments?
2018-5-17
