Cetaman
Flight distance : 2528264 ft
Aloha Pina,
The article for which you posted the link is two pages. Most of the AMA subject matter is on the second page and the link to the second page is not that noticeable in a fast read.
Your comments of a registered flying field are specific to the AMA. The commentary in the article deals with community based organizations (CBO) and the programming of nationwide community-based organizations. The AMA is only the first of other anticipated CBOs. The FAA uses the AMA as an example.
You are making a reasonable leap that therefore the "rules" of the AMA, in particular the registered field rule, will cut down on your flying options. But, as noted it is only an example and not a mandate. Furthermore, membership is not being mandated.
Therefore, you could pick and choose the safety guidelines of CBOs and be informed of the programming of Nationwide CBOs. When asked by the FAA to answer CBO related questions, you show them your safety guidelines and how they come from more than one CBO. Ditto with the programming and how familiar you are with their programs. Knowledge is what counts, not membership dues.
Right now, DJI flying products outnumber all the other sectors of flying hobby products. There is nothing to stop DJI or customers of DJI in the United States from using the DJI standards to create CBOs with a Nationwide CBO Programming (DJI already has programs for fliers). Most of the work has already been done by DJI and the DJI CBO of customers could be independent of DJI but in alliance with DJI. The separation would be required for liability purposes (DJI could even sponsor the CBO). The same could be done with a quadcopter based CBO of flying camera users of different brands.
The first page of the article ends with - According to the FAA: “The FAA solicited comments to its interpretation of the Special Rule for Model Aircraft and received over 33,000 comments, including comments on the use of FPV. The FAA is considering the issues raised by those comments and plans to issue a final interpretation of the Special Rule for Model Aircraft that reflects its consideration of the comments.”
The bottom line is that the regulations are evolving and the FAA has to be fair and equitable. You pointed out a reasonable assumption but that assumption will go extinct quickly as the regulations evolve.
Aloha and Drone On! |
