Olympus mz lens 14-42
878 2 2016-8-27
ricci2
Flight distance : 61158 ft
greetings all,
Just fitted my olympus mz to the x5, and noticed a wee problem with the fitment, the outer focus ring binds on the gimbal housing. After some research it turns out there are two lenses that are very similar but only one of them will fit. I do have the one that is correct as defined by DJI. The lens fits perfect and works perfectly well however I was concerned the focus ring might override the zoom so I got all caveman on it and took the Dremel with a fine sanding wheel and buffed off the knurled outer grip by 0.5 mm for a third of the ring where it touches the gimbal arm, works fine and the zoom operates as it should. I should add I only paid half price for the lens even though it was new due to it not having a box and being an ex-demo, the real question is would I do it to a full priced lens.
Thought I would share if anybody has a desire to re engineer a good bit of glass
R
2016-8-27
Juan carlos3
Flight distance : 31768 ft
The zoom lens can be put on a normal X5 from the year 2016?
2017-5-23
Juan carlos3
A3+LB2 ,Gryphon ,X5
2017-5-23
