Mike-the-cat
Flight distance : 21621841 ft
Singapore
Mindy, Before I send the craft in.... there is one other possibility.
I realised that my v1.0 Inspire (Aircraft B) is on Aircraft firmware version 1.9.1.10. while the v 2.0 Inspire (Aircraft A) is on 1.9.1.30+. The App, camera, RC and A9 Plus versions are otherwise identical on the A / B tests I've made.
I KNOW for a fact that before I upgraded the Aircraft firmware on the v2.0, there was the annoying but harmless 'VPS error'. I had more than 20 flights in late June / early July with that craft with no problems before upgrading the aircraft to 1.9.1.30+ (strange also that there is the '+' which is not on your download website).
As I take great care of my aircraft (no knocks, crashes) and I've checked all cables and such, I do think it is an pure hardware failure but some weird interaction between the new firmware upgrade and that particular aircraft that is a problem. I know that manufacturers occasionally update boards and circuit configurations and I'm pretty sure my problem is such. Otherwise, other pilots would have complained of this.
Please forward this thread to your R&D engineers and get them to send me email directly. You can find my contact details from your database. I have no problems sending my aircraft in if its a hardware issue but just in case there was a patch that inadvertently brought this problem on, I'd like to know. Thanks.
Until this is done, I'll hold back on writing support@dji - I have them on the hook with another issue regarding a LB 1 airside problem and they are simply not good diagnosticians. The engineers who have responded to me follow a set protocol and cannot tell an advanced user from a novice. |
