fans8543dfc2
Flight distance : 278675 ft
South Africa
Konstantin922 Posted at 2017-5-15 16:13
I have this issue, clicked the new update through the DJI assistant app and straight after the update was done the Ronin seems as if Motor Kill is on, this has put me out of work now!!! Does DJI have a solution for this yet?
I have double check that all my physical connections are all good including the battery being in properly. Running out of options need urgent help on this issue.
Hi There
Took out the ronin after few years, I updated the firmware now I have same problem as the one you describe. Do you remember if you found a solution?
