Beginning from 5-9-2016 i have RC connection issues...no firmware / hardware changes
there's too many Mode changed to WiFi_Reconnect
http://healthydrones.com/main?share=LgBknH http://healthydrones.com/main?share=zQCvZR
I see on healthydrones General/notifications there's to many Mode changed to WiFi_Reconnect
same time sensors/signal map gives all green.
I don't known exactly what signal map means, but i suppose it is calculated with signal losses...
The problem here appears to be the link from RC to Drone that is dropping and no weak signal... but why?
How can the connection RC to Drone drop?
Yesterday i had the RC and drone 1 meter away (from each other) on my desk and DGI GO was always changing from good to strong interference... i was 1 meter away from my router but they were so close...
If you are 1m indoors you are going to get signal errors. You need to be outside and further away than that.
Please test in an open area with no interference to see your range.
It it is extremely limited then please contact support and send the aircraft in for evaluation.
Also, please make sure you have correct antenna orientation, here's a video that may help.
i see in General/notifications there's to many "Mode changed to WiFi_Reconnect"... i don't see this in other flights before 3/09/2016, and i made more then 7 hours of flights
why this "Mode changed to WiFi_Reconnect" happens? in what situations? lack of wifi power? interference? or the wifi connection can drop other way?
