Cetaman
Flight distance : 2528264 ft
Aloha oscrfsh,
The Samsung Galaxy Tab Pro 10.1 (inch) is what you want. As DJI-Jamie says, it is not supposed to fit, but it does - just barely. You have to stretch out the holder as far as it can go and the foam allows it to slip in. I have been using mine for more than a year to fly P3P and P4. One secret is to put Painter's Tape over the foam on the top and bottom so it will slide in and out easier - and it just barely does. My foam supports are still in good shape.
But, the USB port is in the middle on the bottom, and the slot on the device holder on the bottom is just too narrow for a USB cable. So, I had to use my Dremel Mototool to grind the slot a little wider. You can also use a rat-tail file for better precision.
Because I have the two Phantoms, I bought a nVidia Shield K1 from the nVidia web site and it is arriving tomorrow. It has an 8 inch display but I plan to use it with my HeadPlay HD goggles. The nVidia Shield K1 is only $200 from nVidia, plus shipping to Hawai'i for me, otherwise shipping is free. It has an HDMI port for goggles. It is the most popular Android device in this Forum and from what I have seen (my friend has one) it is deserving of the reputation.
Hope this helps!
Aloha and Drone On! |
