How to make more smooth paning shots?
Mariuss
Flight distance : 2480515 ft
Norway
Have fiddled a bit with the settings but still not satisfied with the result. I'm looking for less sensitity from center to get as smooth as possible!
Does anyone have some settings that works for them?  fyi: I cant remember mine at the moment.
2016-9-13
mfojas430
Flight distance : 23835 ft
Did you adjust your gain and expo? Gain is the sensitivity. I think you can adjust it between 1-10. The expo is probably what you're looking for. It'll let you adjust it to be less sensitive toward center stick and more sensitive as you go out. This is in the advanced settings I think.
2016-9-13
Mariuss
Norway
mfojas430@insit Posted at 2016-9-13 17:02
Did you adjust your gain and expo? Gain is the sensitivity. I think you can adjust it between 1-10.  ...
Thanks! Isn't gain the 0.2-0.8 one? I mean the settings with elevation, rudder and fwd/aft. Thanks for the expo tip
2016-9-13
dak162
Flight distance : 2999472 ft
The attached information has helped me tremendously.
settings
settings
2016-9-13
Mariuss
Norway
dak162 Posted at 2016-9-13 17:32
You found it!! Thank you Sir.
2016-9-13
wmcvey
Flight distance : 904364 ft
Mariuss Posted at 2016-9-13 11:04
Thanks! Isn't gain the 0.2-0.8 one? I mean the settings with elevation, rudder and fwd/aft. Thanks ...
Expo is one for sure, yaw setting on mine from 0.4 to 0.3.  Also there's the gimbal wheel setting it goes from 1 to 10, mind is set to 6.
2016-9-13
Mariuss
Norway
wmcvey Posted at 2016-9-13 17:35
Expo is one for sure, yaw setting on mine from 0.4 to 0.3.  Also there's the gimbal wheel setting i ...
Got the gimbal settings on point! thanks for the yaw tip
2016-9-13
mfojas430
Mariuss Posted at 2016-9-13 10:04
Looks like you got all the info you needed. Happy flying!
2016-9-14
