A3+LB2 No manual ? Gain ? Please Help !!!
4516 5 2016-9-15
vicart.d
Flight distance : 9088 ft
My configuration :
DJI ASSISTANT 1.05 // DJI A3 V 1.3 // LB2 // PC and MAC
I buy a A3+LB2 for my new X8 900mm with 18" 75A Kde and  Auw 19-22Kg.
I put the A3 on a quadri for test it with différent propeller/trust :
1- regardless of the gains he turns and crash. He’s weight of take off : 7,4 Kg ( 4x U7 18’’ )
Trust of the drone :10 Kg à 50%
18 Kg à 50%
22 Kg à 100 %
2 - regardless of the gains he fly very good ! He’s weight of take off : 9,6 Kg ( 4x U7 15’’ )
6,4 Kg à 50%
12Kg à 75%
16,4 Kg à 100%
Why the "sensibility" on computer for  'Yaw end point is ' 60-300 / ‘brake’ 80-120 / ‘attitude' 20-100  and DIFFERENT on  iPhone
‘attitude’ 20-100 / ‘brake' 30-130 / 'yaw end point' 100-150
My future configuration who i want to fly do 19/23 Kg of take off
Trust of the drone : ( less 15% coaxial )
18 Kg à 50%
36 Kg à 75%
63 Kg à 100%
2016-9-15
vicart.d
There is not setting about the A3, or Manual ??
What is the difference if you chose Esc Dji / or Not. ( If not is it end point of Futaba, Graupner, etc )
There is a option for temperature ?? and do manual mode ??
2016-9-15
vicart.d
NOW  there is Update :DJI ASSISTANT 1.06 // DJI A3 V 1.5
I have always this problems :
ESC CALIBRATION :
I try the esc calibration, pull out the pwm of Esc/A3, clic next, put it, and doesn’t work/turn, or ear nose. If i let plug on the A3 during all the procedure, he turn quick...
It’s don’t work too.
What is the Actuator output ?
LANDING GEAR :
On the screen application of the computer, the landing gear radio channel Move on the Page Radio, Move on the page Landing gear, but not on first page « resume » he don’t work.
I try to put a servo with alimentation, landing gear of S900, nothing.
GAIN :
What i can try on GAIN, Attitude, Brake, Bandwidth ? Hight Number is Hight brake / Hight réponce ?
2016-11-4
vicart.d
I find new bug on "esc setting", i can't change... I all help page are 'blank'.
2016-11-6
AERISRUN
Flight distance : 909685 ft
Réunion
Hi,
Anybody found a solution to calibrate non DJI ESC with A3 and LB2 ?
I have the same issue shown above.
Thanks
2017-1-25
Hansk1
Flight distance : 53619 ft
Finland
Same problem here: A3 / LB2 / tried to calibrate non dji esc's => M1 stopped working!
2018-4-27
