F450 Build and Flight Time
8521 6 2016-9-16
timonroecg
Flight distance : 156401 ft
Build
Frame: F450 ARF KitMotor: 2312, 960 KV
ESC: 420 Lite, 4S 20A
FC: Naza-M V2
OSD: Mark II
Gimbal: H4-3D w/GCU
Camera: GoPro Hero4
Receiver: Futaba
VTX: Flysight
Battery: Tattu 2200 mAh, 4 cell
Takeoff Weight: 3 lbs, 7.4 oz [Note: this is roughly 6oz over the documented weight limit for the 2312 motors]
Flight Time: 7 minutes, 55 seconds [with 14v (13%) remaining in battery].  Hovered at ~20 ft AGL; Location of test: ~280 MSL; Temperature: ~70 F;  No Wind
2016-9-16
DJI-Jamie
Flight distance : 112405 ft
It's a nice build, thanks for sharing. Are you looking to tidy up some of the wires?
2016-9-16
timonroecg
DJI-Jamie Posted at 2016-9-17 00:36
I did spend a fair amount of time folding up the cables (ESCs and others are quite long) but if you have some suggestions I'd be happy to hear them.  Thanks.
2016-9-16
DJI-Jamie
timonroecg@gmai Posted at 2016-9-17 01:54
I did spend a fair amount of time folding up the cables (ESCs and others are quite long) but if yo ...
I try to evenly distribute the cabling around the vacinity of the closest ESC cabling and zip tie around the slack loosly. I can see some of the tidying you've done thus far, I know it can be a little difficult with a smaller frame.
2016-9-16
vladimir57
You can not get more flight time in this configuration. You can try to use a higher capacity battery (about 4-5 a/h), and the "C" parameter is not more than 20-25. Using high-quality propellers made of carbon fiber, you will achieve better performance. However, their use can lead to the failure of the camera stabilization. This can be eliminated by using softer rubber insert between the "F450" and "Zenmuze N3-4".
Try to make as short as possible wires from the battery to the ESC. This is not the best use. Reducing the voltage drop across these wires will improve model performance and reduce the magnetic field around GPS compass.
I wish you success!
2016-10-15
timonroecg
vladimir57 Posted at 2016-10-15 21:26
You can not get more flight time in this configuration. You can try to use a higher capacity batter ...
Thanks vladimir57 for your feedback.  This F450 is my experimental copter so in the process of rebuilding it now.  I didn't like the weight distribution of the components (mainly the gimbal/camera) so creating a center mount configuration instead along with a few other modifications.  Will post pics when I'm done.
2016-10-15
vladimir57
timonroecg@gmai Posted at 2016-10-15 11:23
Thanks vladimir57 for your feedback.  This F450 is my experimental copter so in the process of reb ...
Полёты на простых моделях помогут приобрести необходимые навыки пилотирования и опыт для перехода к более сложным моделям. Искренне желаю Вам успехов в Вашем творчестве!
2016-10-15
