vladimir57
Try to change only one product from the ESC on "DJI", which has the same parameters. Calibrate it on the motors that you are going to use. If the motor is connected to the ESC will work - there is a problem in programming your regulators. Not all regulators work equally well when first turned on. Some of their characteristics are needed to be programmed . You could accidentally, during calibration ESC, enter the programming menu control (for example, if you have not moved the power consumption of the stick in less than 3 seconds after heard the first "beep-beep" from the motor). Try only one ESC recommended by "DJI".
To get +5 volts, you can use any BEC 5 volts and a current of 3 amp from any manufacturer. Do not connect this wire with your receiver or camera with controllers A2 or Naza. |
