Ronin MX motor tuning parameters explanation
2325 3 2016-9-24
andrey
Russia
Ronin`s user manual says:
"Do not adjust the default Strength, Outfilter or Control values unless you are an advanced user. "
I think i`m advanced gimbal user, I started with DIY Alexmos gimbals, I have two classic ronins, one Ronin-M and one RoninMX, three Z-gimbals(NEX, BMPCC and 5D) and some gopro stuff. I have a lot of experience with tuning and balancing with this things...But I can`t completely understand what effect do these new settings: Strength, Outfilter and Control.
I need an advenced explanation for the advanced user.
(understanding of outfilter is much more easy than two other option, but I want to see the relativity of 0-100 scale to frequencies)
2016-9-24
Ali Osman KILIÇ
Flight distance : 1017162 ft
Turkey
What should be the outfitter values
2016-10-16
andrey
Russia
Ali Osman KILIÇ Posted at 2016-10-17 08:15
It`s should to be some kind of frequency filtering and dampening, if you had experience with the ALEXMOS controllers, it also have that parameter in PID settings, the last one D - Dampening. And if you raise it too much it will make your stabilisation worse.
In terms of dji, I`m not very sure about this outfilter parameter but maybe it does the same...
2016-10-17
fans20c7ca9d
Mexico
i'm trying with everything but strenght to 0 and it seems to be working ok
2016-12-31
