daninperth
Hi David,
I took it out for two more runs and it performed very well. No untoward drift and held position once I took hands off sticks. I was a bit cautious at first but because I was in a very large field with plenty of room for error, I swung it around quite briskly. Tried different modes, let it drift to see what it would do in A mode. Took it full throttle on some longer runs to see if I got the halting effect that you want to see in P mode when not easing off the stick but instead letting it go abruptly. That worked out well it did what it should. I am tempted to say that the calibration worked. So to answer your second question, I will now do it before every session. I don't feel like we should have to but if that's what it takes to replicate that great flying experience then so be it. You know I did notice a bit of squirrely behavior in the first three flights of the day. I was at higher altitudes and trees were not an issue. I had more than enough room for what I considered to be slightly abnormal behavior. However on my fourth flight when my flyaway happened, I was flying very conservatively and in strictly P mode. I was also flying under tree height when she bolted for the trees. She took off on her own while I was not even touching the sticks. I throttled down and by the time she reached the treeline she bounced onto the ground. When I did react and put my hands back on the sticks, It did not seem to respond to any commands other than weakly to the down throttle. I really didn't have time to do much else anyway.
I am going to Calibrate that IMU before each day's session unless someone with greater knowledge tells me otherwise. I had calibrated twice since the last firmware update. Also make sure you get used to the Inspire's normal behavior...if you get this sorted out that is. You mention you've been flying already for a year so I guess already know what normal behavior is. I had many weeks of good stable flight with this machine before today's events.
Edit: Today I had another event but this seemed different from my first one. I simply toggled into A mode and then regained control. This time I was flying at some altitude and wind was steady in the 10 MPH range.
Dan |
