VQDz4qRr3NSc
Hi all,
Problem #1
Experiencing some issues with a DJI Inspire 1 Raw; the gimbal was recently repaired by DJI and seems to work correctly, except that it faces exactly 90 degrees to the right, despite the app/compass showing that it is facing the same way as the drone. Basically the yaw is 90 degrees off, after numerous IMU, compass and gimbal calibrations. It does seem to be setting itself up correctly each time, but then pressing 'reset yaw' or powering off and on the drone/controllers in any sequence resets the yaw to its default sideways position. Our initial thought is to roll back the firmware and reinstall to see if that resolves the issue. However, this introduces...
Problem #2
The drone won't take any firmware via a micro SD card. It simply doesn't register it, makes no sound, remains static, and the light blinks yellow. We've tried different micro SD cards, formatted on different computers, different .bin files, even using different unarchiving programs. We also tried hooking the drone up directly to a mac and to a Fat 32 hard drive via USB. Makes no difference. The bird is currently on 1.9.30 and we're ultimately trying to roll back to 1.8.1.00 in order to troubleshoot Problem 1.
Thanks for any ideas!
