Sekafetz
I brought my P3P out after a few months on mon-use. The App had updated to the point that I had to do a firmware upgrade. So I tried 1.8 and it simply just did not take. After a month of frustration, I contacted DJI, after a month, I was told to send a video. Now another month later, I have tried to upload unsuccessfully the video, but also tried to install 10, 8, 3, 1 (yes I tried just to get a base if possible), 4, then 9.
My question is, is it worth sending the P3P back for repair?
My log:
Result: Failed.
Reboot the aircraft and try to upgrade the firmware again.
========== 2014.01.01 00:00:13 remo-con disconnect======
Packet: P3X_FW_V01.10.0090.bin
Result: Failed.
========== 2014.01.01 00:00:15 remo-con disconnect======
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.03.0020.bin
Result: Failed.
Packet: P3X_FW_V01.08.0080.bin
Result: Failed.
Result: Failed.
========== 2014.01.01 00:00:14 remo-con disconnect======
Result: Failed.
Packet: P3X_FW_V01.01.0008.bin
Result: Corrupted.
Firmware bin file is corrupted, download it again from the DJI offical website.
Result: Corrupted.
Packet: P3X_FW_V01.04.0010.bin
Result: Failed.
Result: Failed.
Packet: P3X_FW_V01.09.0060.bin
Result: Failed.
========== 2014.01.01 00:00:12 remo-con disconnect======
Result: Failed.
Result: Failed.
and my Hidden log:
[00014350][01 00] Firmware upgrade finished successfully.
[00014526]Done.
[00014626]Packet [C:\P3X_FW_V01.10.0090.bin] resumed, card sn [0xa0ce3567].
[00014769]Packet vlink 01.10.0090 <-> 01.10.0090.
[00014904]Version checking[2]...
[00015090][03 05][00] v34.2.0.8 -> v34.2.0.9 need upgrade.
[00015190][03 06][00] v2.1.6.7 -> v2.4.20.28 need upgrade.
[00015229][04 00][00] v1.36.0.0 -> v1.48.0.0 need upgrade.
[00015331][11 00][00] v1.6.0.0 -> v1.8.0.0 need upgrade.
[00015450][11 01][00] v1.6.0.0 -> v2.0.0.33, firmware v1.6.0.0 not support.
[00015482][11 01][00] v1.6.0.0 -> v2.0.0.33
[00015562][12 00][00] v1.7.0.0 -> v1.11.0.0 need upgrade.
[00015644][12 01][00] v1.7.0.0 -> v1.11.0.0 need upgrade.
[00015745][12 02][00] v1.7.0.0 -> v1.11.0.0 need upgrade.
[00015820][12 03][00] v1.7.0.0 -> v1.11.0.0 need upgrade.
[00028361][15 00][00] device not detected.
[00028438][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[00028539][17 01][00] v1.0.2.4 -> v1.0.2.7 need upgrade.
[00028579][19 00][00] v1.0.8.59 -> v1.0.8.96 need upgrade.
[00028612][01 00][05] v1.32.5432 -> v1.32.5432
[00028647][01 01][00] v1.6.2736 -> v1.32.5432 need upgrade
[00041180][08 00][00] device not detected.
[00041241][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00041272]Done.
[00041303]Firmware upgrading[2]...
[00041453][01 01] Firmware upgrade start...
[00071719][01 01] Firmware upgrade finished successfully.
[00071777][12 00] Firmware upgrade start...
[00140573][12 00] Firmware upgrade finished successfully.
[00140623][12 01] Firmware upgrade start...
[00203840][12 01] Firmware upgrade finished successfully.
[00203895][12 02] Firmware upgrade start...
[00263982][12 02] Firmware upgrade finished successfully.
[00264034][12 03] Firmware upgrade start...
[00334140][12 03] Firmware upgrade finished successfully.
[00334206][17 00] Firmware upgrade start...
[00376741][17 00] Firmware upgrade finish failed (step = 2, err = 0xaa).
[00406785][17 01] Firmware upgrade start...
[00466867][17 01] Firmware upgrade finished successfully.
[00467002][11 00] Firmware upgrade start...
[00516919][11 00] Firmware upgrade finished successfully.
[00516970][03 05] Firmware upgrade start...
[00586955][03 05] Firmware upgrade finished successfully.
[00587232][03 06] Firmware upgrade start...
[00977628][03 06] Firmware upgrade finished successfully.
[00980770][19 00] Firmware upgrade start...
[00991103][19 00] stop streaming timeout, continue upgrade.
[01135239][19 00] start streaming timeout, continue upgrade.
[01165276][19 00] Firmware upgrade finished successfully.
[01165335][09 00] Firmware upgrade start...
[01217388][09 00] Firmware upgrade finished successfully.
[01217454][04 00] Firmware upgrade start...
[01275978][04 00] Firmware upgrade finished successfully.
[01276016]Done.
[01276054]Version checking[3]...
[01276119][03 05][05] v34.2.0.9 -> v34.2.0.9
[01276199][03 06][05] v2.4.20.28 -> v2.4.20.28
[01276249][04 00][05] v1.48.0.0 -> v1.48.0.0
[01276359][11 00][05] v1.8.0.0 -> v1.8.0.0
[01276479][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01276512][11 01][00] v1.8.0.0 -> v2.0.0.33
[01276593][12 00][05] v1.11.0.0 -> v1.11.0.0
[01276708][12 01][05] v1.11.0.0 -> v1.11.0.0
[01276798][12 02][05] v1.11.0.0 -> v1.11.0.0
[01276875][12 03][05] v1.11.0.0 -> v1.11.0.0
[01289417][15 00][00] device not detected.
[01289488][17 00][00] v1.1.1.2 -> v1.1.1.7 need upgrade.
[01289608][17 01][05] v1.0.2.7 -> v1.0.2.7
[01289668][19 00][05] v1.0.8.96 -> v1.0.8.96
[01289704][01 00][05] v1.32.5432 -> v1.32.5432
[01289744][01 01][05] v1.32.5432 -> v1.32.5432
[01302277][08 00][00] device not detected.
[01302329][09 00][05] v3.0.0.10 -> v3.0.0.10
[01302366]Done.
[01302404]Firmware upgrading[3]...
[01302465][17 00] Firmware upgrade start...
[01380007][17 00] Firmware upgrade finished successfully.
[01380041]Done.
[01380073]Version checking[4]...
[01380146][03 05][05] v34.2.0.9 -> v34.2.0.9
[01380225][03 06][05] v2.4.20.28 -> v2.4.20.28
[01380379][04 00][05] v1.48.0.0 -> v1.48.0.0
[01380512][11 00][05] v1.8.0.0 -> v1.8.0.0
[01380625][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01380661][11 01][00] v1.8.0.0 -> v2.0.0.33
[01380753][12 00][05] v1.11.0.0 -> v1.11.0.0
[01380833][12 01][05] v1.11.0.0 -> v1.11.0.0
[01380932][12 02][05] v1.11.0.0 -> v1.11.0.0
[01381024][12 03][05] v1.11.0.0 -> v1.11.0.0
[01393557][15 00][00] device not detected.
[01393636][17 00][05] v1.1.1.7 -> v1.1.1.7
[01393758][17 01][05] v1.0.2.7 -> v1.0.2.7
[01393807][19 00][05] v1.0.8.96 -> v1.0.8.96
[01393842][01 00][05] v1.32.5432 -> v1.32.5432
[01393884][01 01][05] v1.32.5432 -> v1.32.5432
[01406434][08 00][00] device not detected.
[01406491][09 00][05] v3.0.0.10 -> v3.0.0.10
[01406535]Packet upgrade failed at version checking.
[00012757]========== remo-con disconnect. boot(15) ============
[00012857]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xbaf80d72].
[00012894]Packet upgrade start...
[00012937]Packet checking...
[00012979]Packet vlink 01.10.0090 <-> 01.10.0090.
[00013045]Done.
[00013080]Version checking[1]...
[00013152][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013212][03 06][00] v2.4.20.28 -> v2.4.20.28
[00013261][04 00][00] v1.48.0.0 -> v1.48.0.0
[00013393][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013513][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013548][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013687][12 00][00] v1.11.0.0 -> v1.11.0.0
[00013796][12 01][00] v1.11.0.0 -> v1.11.0.0
[00013877][12 02][00] v1.11.0.0 -> v1.11.0.0
[00013973][12 03][00] v1.11.0.0 -> v1.11.0.0
[00026506][15 00][00] device not detected.
[00026577][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026700][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026758][19 00][00] v1.0.8.96 -> v1.0.8.96
[00026794][01 00][00] v1.32.5432 -> v1.32.5432
[00026838][01 01][00] v1.32.5432 -> v1.32.5432
[00039373][08 00][00] device not detected.
[00039437][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039601]Packet upgrade failed at version checking.
[00014827]========== remo-con disconnect. boot(15) ============
[00014864]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xbaf80d72].
[00014901]Packet upgrade start...
[00014945]Packet checking...
[00014987]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015053]Done.
[00015087]Version checking[1]...
[00015160][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015224][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015269][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015405][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015561][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015594][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015694][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015781][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015889][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015994][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028537][15 00][00] device not detected.
[00028609][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028749][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028795][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028841][01 00][00] v1.32.5432 -> v1.32.5432
[00028874][01 01][00] v1.32.5432 -> v1.32.5432
[00041450][08 00][00] device not detected.
[00041515][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041553]Packet upgrade failed at version checking.
[00014832]========== remo-con disconnect. boot(15) ============
[00014870]Packet [C:\P3X_FW_V01.10.0090.bin] detected, card sn [0xbaf80d72].
[00014908]Packet upgrade start...
[00014947]Packet checking...
[00014989]Packet vlink 01.10.0090 <-> 01.10.0090.
[00015059]Done.
[00015092]Version checking[1]...
[00015172][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015232][03 06][00] v2.4.20.28 -> v2.4.20.28
[00015275][04 00][00] v1.48.0.0 -> v1.48.0.0
[00015370][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015551][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015587][11 01][00] v1.8.0.0 -> v2.0.0.33
[00015681][12 00][00] v1.11.0.0 -> v1.11.0.0
[00015755][12 01][00] v1.11.0.0 -> v1.11.0.0
[00015827][12 02][00] v1.11.0.0 -> v1.11.0.0
[00015982][12 03][00] v1.11.0.0 -> v1.11.0.0
[00028519][15 00][00] device not detected.
[00028596][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028716][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028763][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028800][01 00][00] v1.32.5432 -> v1.32.5432
[00028842][01 01][00] v1.32.5432 -> v1.32.5432
[00041416][08 00][00] device not detected.
[00041490][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041527]Packet upgrade failed at version checking.
[00014883]========== remo-con disconnect. boot(15) ============
[00014930]Packet [C:\P3X_FW_V01.03.0020.bin] detected, card sn [0xbaf80d72].
[00014973]Packet upgrade start...
[00015019]Packet checking...
[00015059]Packet vlink 01.03.0020 <-> 01.01.0009.
[00015131]Done.
[00015175]Version checking[1]...
[00015248][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015328][03 06][00] v2.4.20.28 -> v2.2.6.19
[00015380][04 00][00] v1.48.0.0 -> v1.40.0.0
[00015442][09 00][00] v3.0.0.10 -> v1.7.0.3
[00015569][11 00][00] v1.8.0.0 -> v1.7.0.0
[00015662][12 00][00] v1.11.0.0 -> v1.8.0.0
[00015763][12 01][00] v1.11.0.0 -> v1.8.0.0
[00015868][12 02][00] v1.11.0.0 -> v1.8.0.0
[00015952][12 03][00] v1.11.0.0 -> v1.8.0.0
[00028498][15 00][00] device not detected.
[00028597][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028740][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028803][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028853][01 00][00] v1.32.5432 -> v1.23.3419
[00028895][01 01][00] v1.32.5432 -> v1.23.3419
[00041435][08 00][00] device not detected.
[00041476]Packet upgrade failed at version checking.
[00014819]========== remo-con disconnect. boot(15) ============
[00014863]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0xbaf80d72].
[00014899]Packet upgrade start...
[00014940]Packet checking...
[00014983]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015050]Done.
[00015153][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015230][03 06][00] v2.4.20.28 -> v2.4.14.5
[00015352][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015553][11 00][00] v1.8.0.0 -> v1.7.15.1
[00015638][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015717][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015808][12 02][00] v1.11.0.0 -> v1.10.0.0
[00015897][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028435][15 00][00] device not detected.
[00028537][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028658][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028703][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028740][01 00][00] v1.32.5432 -> v1.30.5036
[00028780][01 01][00] v1.32.5432 -> v1.30.5036
[00041329][08 00][00] device not detected.
[00041465][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041507]Packet upgrade failed at version checking.
[00014822]========== remo-con disconnect. boot(15) ============
[00014866]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0xbaf80d72].
[00014903]Packet upgrade start...
[00014946]Packet checking...
[00014990]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015062]Done.
[00015098]Version checking[1]...
[00015175][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015235][03 06][00] v2.4.20.28 -> v2.4.14.5
[00015455][11 00][00] v1.8.0.0 -> v1.7.15.1
[00015544][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015618][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015714][12 02][00] v1.11.0.0 -> v1.10.0.0
[00015801][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028342][15 00][00] device not detected.
[00028420][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028561][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028624][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028668][01 00][00] v1.32.5432 -> v1.30.5036
[00028705][01 01][00] v1.32.5432 -> v1.30.5036
[00041327][08 00][00] device not detected.
[00041385][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041427]Packet upgrade failed at version checking.
[00014835]========== remo-con disconnect. boot(15) ============
[00014874]Packet [C:\P3X_FW_V01.08.0080.bin] detected, card sn [0xbaf80d72].
[00014909]Packet upgrade start...
[00014951]Packet checking...
[00015085]Packet vlink 01.08.0080 <-> 01.07.0060.
[00015161]Done.
[00015199]Version checking[1]...
[00015281][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015440][03 06][00] v2.4.20.28 -> v2.4.14.5
[00015486][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015600][11 00][00] v1.8.0.0 -> v1.7.15.1
[00015709][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015783][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015888][12 02][00] v1.11.0.0 -> v1.10.0.0
[00015988][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028529][15 00][00] device not detected.
[00028630][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028769][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028840][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028879][01 00][00] v1.32.5432 -> v1.30.5036
[00028987][01 01][00] v1.32.5432 -> v1.30.5036
[00041526][08 00][00] device not detected.
[00041579][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041616]Packet upgrade failed at version checking.
[00014910]========== remo-con disconnect. boot(15) ============
[00014964]Packet [C:\P3X_FW_V01.01.0008.bin] detected, card sn [0xbaf80d72].
[00015004]Packet upgrade start...
[00015055]Packet checking...
[00015093]Packet upgrade failed at packet checking.
[00014918]========== remo-con disconnect. boot(15) ============
[00014970]Packet [C:\P3X_FW_V01.01.0008.bin] detected, card sn [0xbaf80d72].
[00015008]Packet upgrade start...
[00015060]Packet checking...
[00015101]Packet upgrade failed at packet checking.
[00012924]========== remo-con disconnect. boot(15) ============
[00012970]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbaf80d72].
[00013009]Packet upgrade start...
[00013063]Packet checking...
[00013105]Packet vlink 01.04.0010 <-> 01.03.0020.
[00013187]Done.
[00013232]Version checking[1]...
[00013324][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013418][03 06][00] v2.4.20.28 -> v2.3.0.13
[00013478][04 00][00] v1.48.0.0 -> v1.41.0.0
[00013538][09 00][00] v3.0.0.10 -> v1.7.0.3
[00013677][11 00][00] v1.8.0.0 -> v1.7.0.0
[00013776][12 00][00] v1.11.0.0 -> v1.10.0.0
[00013946][12 01][00] v1.11.0.0 -> v1.10.0.0
[00014046][12 02][00] v1.11.0.0 -> v1.10.0.0
[00014130][12 03][00] v1.11.0.0 -> v1.10.0.0
[00026673][15 00][00] device not detected.
[00026766][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026906][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026977][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027026][01 00][00] v1.32.5432 -> v1.23.3419
[00027067][01 01][00] v1.32.5432 -> v1.23.3419
[00039609][08 00][00] device not detected.
[00039662]Packet upgrade failed at version checking.
[00014940]========== remo-con disconnect. boot(15) ============
[00014983]Packet [C:\P3X_FW_V01.04.0010.bin] detected, card sn [0xbaf80d72].
[00015034]Packet upgrade start...
[00015081]Packet checking...
[00015131]Packet vlink 01.04.0010 <-> 01.03.0020.
[00015203]Done.
[00015247]Version checking[1]...
[00015340][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015417][03 06][00] v2.4.20.28 -> v2.3.0.13
[00015480][04 00][00] v1.48.0.0 -> v1.41.0.0
[00015549][09 00][00] v3.0.0.10 -> v1.7.0.3
[00015676][11 00][00] v1.8.0.0 -> v1.7.0.0
[00015764][12 00][00] v1.11.0.0 -> v1.10.0.0
[00015864][12 01][00] v1.11.0.0 -> v1.10.0.0
[00015969][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016069][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028616][15 00][00] device not detected.
[00028724][17 00][00] v1.1.1.7 -> v1.1.1.7
[00028864][17 01][00] v1.0.2.7 -> v1.0.2.7
[00028930][19 00][00] v1.0.8.96 -> v1.0.8.96
[00028978][01 00][00] v1.32.5432 -> v1.23.3419
[00029023][01 01][00] v1.32.5432 -> v1.23.3419
[00041570][08 00][00] device not detected.
[00041610]Packet upgrade failed at version checking.
[00015070]========== remo-con disconnect. boot(15) ============
[00015116]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xbaf80d72].
[00015166]Packet upgrade start...
[00015219]Packet checking...
[00015265]Packet vlink 01.09.0060 <-> 01.08.0080.
[00015346]Done.
[00015395]Version checking[1]...
[00015486][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015648][03 06][00] v2.4.20.28 -> v2.4.20.18
[00015700][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015806][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015927][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015974][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016060][12 00][00] v1.11.0.0 -> v1.10.0.0
[00016160][12 01][00] v1.11.0.0 -> v1.10.0.0
[00016240][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016316][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028870][15 00][00] device not detected.
[00028956][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029078][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029158][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029201][01 00][00] v1.32.5432 -> v1.30.5036
[00029249][01 01][00] v1.32.5432 -> v1.30.5036
[00041797][08 00][00] device not detected.
[00041877][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041921]Packet upgrade failed at version checking.
[00012962]========== remo-con disconnect. boot(15) ============
[00013004]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xbaf80d72].
[00013048]Packet upgrade start...
[00013102]Packet checking...
[00013151]Packet vlink 01.09.0060 <-> 01.08.0080.
[00013228]Done.
[00013270]Version checking[1]...
[00013353][03 05][00] v34.2.0.9 -> v34.2.0.9
[00013428][03 06][00] v2.4.20.28 -> v2.4.20.18
[00013482][04 00][00] v1.48.0.0 -> v1.44.0.0
[00013608][11 00][00] v1.8.0.0 -> v1.8.0.0
[00013728][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00013770][11 01][00] v1.8.0.0 -> v2.0.0.33
[00013858][12 00][00] v1.11.0.0 -> v1.10.0.0
[00013940][12 01][00] v1.11.0.0 -> v1.10.0.0
[00014027][12 02][00] v1.11.0.0 -> v1.10.0.0
[00014116][12 03][00] v1.11.0.0 -> v1.10.0.0
[00026672][15 00][00] device not detected.
[00026758][17 00][00] v1.1.1.7 -> v1.1.1.7
[00026905][17 01][00] v1.0.2.7 -> v1.0.2.7
[00026978][19 00][00] v1.0.8.96 -> v1.0.8.96
[00027023][01 00][00] v1.32.5432 -> v1.30.5036
[00027068][01 01][00] v1.32.5432 -> v1.30.5036
[00039618][08 00][00] device not detected.
[00039779][09 00][00] v3.0.0.10 -> v3.0.0.10
[00039828]Packet upgrade failed at version checking.
[00015073]========== remo-con disconnect. boot(15) ============
[00015127]Packet [C:\P3X_FW_V01.09.0060.bin] detected, card sn [0xbaf80d72].
[00015170]Packet upgrade start...
[00015222]Packet checking...
[00015269]Packet vlink 01.09.0060 <-> 01.08.0080.
[00015343]Done.
[00015397]Version checking[1]...
[00015475][03 05][00] v34.2.0.9 -> v34.2.0.9
[00015575][03 06][00] v2.4.20.28 -> v2.4.20.18
[00015637][04 00][00] v1.48.0.0 -> v1.44.0.0
[00015755][11 00][00] v1.8.0.0 -> v1.8.0.0
[00015874][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00015930][11 01][00] v1.8.0.0 -> v2.0.0.33
[00016028][12 00][00] v1.11.0.0 -> v1.10.0.0
[00016135][12 01][00] v1.11.0.0 -> v1.10.0.0
[00016218][12 02][00] v1.11.0.0 -> v1.10.0.0
[00016315][12 03][00] v1.11.0.0 -> v1.10.0.0
[00028980][17 00][00] v1.1.1.7 -> v1.1.1.7
[00029099][17 01][00] v1.0.2.7 -> v1.0.2.7
[00029160][19 00][00] v1.0.8.96 -> v1.0.8.96
[00029214][01 00][00] v1.32.5432 -> v1.30.5036
[00029263][01 01][00] v1.32.5432 -> v1.30.5036
[00041814][08 00][00] device not detected.
[00041881][09 00][00] v3.0.0.10 -> v3.0.0.10
[00041930]Packet upgrade failed at version checking.
