steve.dawson
Flight distance : 2760564 ft
New Zealand
Hi Natalia,
I use my Inspire 1 for photogrammetry so the accuracy of the image timestamps is very important. If the timestamps are taken from the device running the "GO" app, this is not good. It's especially not good if you use an iPad Air 2 (as I do). On the wifi-only Air2, the time drifts between synchronisations (which apparently happens when you are a network, and open Safari, or similar). So, in the wilderness, the accuracy of the timestamps will drift.
Since the Inspire has it's own GPS, I'd assumed the image timestamps would be based on GPS time. It would be way better if they were. Could you please pass this on...
Thanks, Steve |
