ty.thorsen
I currently have two aircraft, P3A and P3P. My P3A flies like a dream, never having had a problem. Because of this experience, I have recommended it to my father, who I have now bought a P3P for. I have updated downloaded the app, updated the firmware, and checked the text file generated on the sd card for proper installation. I took the P3P a local field and calibrated both the IMU (status screen said that IMU calibration was required) and the compass. Everything appeared to be ok, so I took off...
After about 10 second of flying, the app said "Atti-Mode" and the aircraft began veering hard in one direction. I brought it back in manually. I turned everything off and back on again, recalibrated everything, and rechecked the firmware versions (all looked good). I took off a second time, staying lower to the ground and flying a few circular patterns. I figured out the the aircraft turns to "Atti-Mode" everytime it faces west, and until you turn it nearly 180 degrees the opposite way, it will stay in atti-mode.
Concerned that this problem may be because of the area I was in (an open field), I took out my P3A, flew it for 20+minutes in all directions, and had zero problems.
What can I do about my P3P switching to atti-mode when it faces west? I cannot in good-faith give this to my father, as he would end up having a fly-away...
