P3 Standrd filmware
1043 8 2016-10-12
supergtr35
I have just upgrade my Phantom3 Standard filmware and the singal cannot go over 25m. Anyone have this issue too?
Never happen before i update the filmware. Any way to downgrade it?
2016-10-12
ciro.matera
anyone that up to 1.6.08 has your issue, search "downgrade firmware" in forum or WAIT, seems there is a beta (1.7)
2016-10-12
supergtr35
ciro.matera Posted at 2016-10-12 18:17
anyone that up to 1.6.08 has your issue, search "downgrade firmware" in forum or WAIT, seems there i ...
My friend happen the same but i cannot find anyone here have this issue. What should i do?
2016-10-12
ciro.matera
supergtr35@hotm Posted at 2016-10-12 12:34
search and read the posts
"Finally some distance!!"
AND
"Latest P3S Firmware Downgrade Steps"
AND
"DIY Antenna Booster for Phantom 3"
But i had downgraded, without any effect
today i'll apply the patch to CE to FCC
cross my fingers
2016-10-12
supergtr35
ciro.matera Posted at 2016-10-12 18:40
AND
You have the same isse on the new filmware?
Which filmware you downgrade to to get it fix?
Thanks.
2016-10-12
rr
Denmark
i updatet to 1.7.8 but havent tryed it out yet as its bad weather here.have read on the net that people who updatet with the beta 1.7.8 has a range over 1.2.km without any extented help.
but you can downgrade from 1.6.8 to 1.5.7.
just download the 1.5.7 to an empty sd card as the only file has to be on the card is the 1.5.7 binfile.then put it in the drone and power it up wait until the backlight turn green.then check the textfile on a pc from the card if it says succes you are baxk on 1.5.7 remember to format the card and put it back in the drone
2016-10-12
cekabu
Flight distance : 9154 ft
Turkey
You will not be able to solve your range problem. Downgrade, upgrade, beta softwares nothing works. Almost half of the p3s owners have this problem and DJI doesn't do anything about that. DJI paladine mode on: check your antenna positions
2016-10-13
cdikland
Flight distance : 229911 ft
cekabu Posted at 2016-10-13 07:33
You will not be able to solve your range problem. Downgrade, upgrade, beta softwares nothing works.  ...
Thats a bit of a stretch...... Anyway... the OP says the P3S worked fine and the limited range became on issue only after upgrading. Sounds like the P3S worked fine before the upgrade.
2016-10-13
cekabu
Turkey
cdikland Posted at 2016-10-13 15:51
Thats a bit of a stretch......  Anyway... the OP says the P3S worked fine and the limited ...
Yes range problem starts with 1.6.80 upgrade. Before that it is normal
2016-10-13
