New Firmware for Phantom series Remote Control
1234567Next >
18530 245 2016-10-13
Overview:
1. Ground system updated to v1.8.0
2. DJI GO app iOS version updated to v3.0.0. DJI GO app Android version updated to v3.0.0.
What’s New:
1. Improved video stream quality when using GL300A Remote Controller to record 2.7K video.
2.   Enhanced Remote Controller and mobile device connection stability.
Notes:
This firmware applies to the following models: Phantom 3 Professional / Phantom 3 Advanced / Phantom 4
If the RC firmware version below v1.3.2, please upgarde it with USB drive to v1.3.2 firstly, then upgrade it to the latest through DJI GO APP.
2016-10-13
Relic
Czechia
Im not getting the option to upgrade, even after updating app and relaunching
2016-10-13
Kassur
Flight distance : 30620 ft
Same here, no update!
2016-10-13
Astronappa
Since downloading DJI GO newest version I'm unable to find the update for the RC. it says I'm currntly on version 1.6.0.  Everything seems fine other than the C1 button promps some menu about communicating with DJI app, and I cannot get the horizon tilt to respond with the C2 button like it used to?
2016-10-13
ben_m16
Flight distance : 5459859 ft
No update...... whats happens?????
2016-10-13
microcyb
Flight distance : 1095955 ft
Mindy Mindy Mindy.
You need to tell the development team to fix the standard line base code.
{:4_117:}
2016-10-13
Total
Flight distance : 336480 ft
No update indicated in the DJI Go app ...
2016-10-13
Aardvark
Flight distance : 384432 ft
+1 Bump !!!
2016-10-13
rpmurph83
Flight distance : 1048783 ft
same here. just tried it and no update is showing up.
2016-10-13
drag line
Flight distance : 151299 ft
Not getting any notice to update. Please advise
2016-10-13
julmirecki
Flight distance : 368186 ft
Does the Remote version has anything to do with this update?
Mine is GL300C, but the post states: "Improved video stream quality when using GL300A Remote Controller to record 2.7K video."
2016-10-13
mktdaffron
Belize
Same problem here. It happened to me after upgrading to ios 10. I cant level my horizon with C1 and my target mark is way to the top left LOL, RC doesnt respond at times. HELP!!!
2016-10-13
wcharwood
Flight distance : 484652 ft
DJI Mindy - could you please advise us of what the problem is? I do not see the update you described and other people are anxiously waiting some reply from DJI.
2016-10-13
wcharwood Posted at 2016-10-14 08:34
DJI Mindy - could you please advise us of what the problem is? I do not see the update you described ...
Could you please make sure your mobile device connect to the network successfully?
2016-10-13
ben_m16 Posted at 2016-10-14 02:30
Please try to restart the app and make sure the device connect to the network successfully.
2016-10-13
Astronappa Posted at 2016-10-13 22:52
Since downloading DJI GO newest version I'm unable to find the update for the RC. it says I'm currnt ...
As for the C1 issue, please close the DJI Go app, then connect your aircraft with the RC and press the C1 button.
The notification saying "DJI Go would like to communicate with the C1 Button" will appear.
Click "allow" and the DJI Go app will open automatically.
After that, you will no longer get the popup.
And please try to restart the app to see if you would get the update notice.
2016-10-13
julmirecki Posted at 2016-10-14 06:53
Mine is GL300C, but the post states: "I ...
Also as mentioned in second point, the new firmware will enhanced Remote Controller and mobile device connection stability.
2016-10-13
Please try to restart the app and make sure the device is connect to network successfully.
If you still cannot update the RC, please feel free to let me know.
@Relic @Kassur  @microcyb @Total  @Aardvark  @rpmurph83 @drag line
2016-10-13
timjd3
Flight distance : 531217 ft
DJI Mindy Posted at 2016-10-13 19:29
Also as mentioned in second point, the new firmware will enhanced Remote Controller and mobile dev ...
Same problem as others.   Will not update from 1.6.0 on the 3.0 app.   I've rebooted and restarted everything multiple times (as I'm sure have others).
Does not work.
2016-10-13
timjd3@cox.net Posted at 2016-10-14 10:37
Same problem as others.   Will not update from 1.6.0 on the 3.0 app.   I've rebooted and restarted ...
Have you tried to change the network from wifi to cellular network?
2016-10-13
timjd3
DJI Mindy Posted at 2016-10-13 19:46
Yup.   Have tried on WiFi and Cellular.   Rebooted, restarted and reloaded.   While we're at it, also tried on two different ipads and a cell phone.
Might want to consider the possibility it's at your end.
2016-10-13
timjd3@cox.net Posted at 2016-10-14 11:22
Yup.   Have tried on WiFi and Cellular.   Rebooted, restarted and reloaded.   While we're at it, a ...
Thanks for your feedback.
I have brought this to the attention of our support team.
And it's fix now.Could you please try again and let me know the result?
2016-10-13
PartsGuy
Flight distance : 418346 ft
DJI Mindy Posted at 2016-10-13 20:46
Mindy, I've tried everything. it will not bring up update in cellular, wi-fi or anything I try.
2016-10-13
kyapkk
Malaysia
PartsGuy Posted at 2016-10-14 12:15
Same here, can't get update also.
2016-10-13
NiQWXMY8la10
OK I know this is a total newbie question, but How can I see the update versions on both the RC and the drone??? I've had the RC updated just this night, but is tis the same ver. I'm seeing in the DJI Assistant? meaning the RC or the drone version???
2016-10-13
rpmurph83
The fix mentioned by Mindy is just a temporary fix for that single session. I contacted DJI directly regarding the problem with the C1 button and was told they are aware of the issue and trying to fix it. If you shutdown the controller and app and then re-open the issue with the C1 button returns, at least in my case.
2016-10-13
rpmurph83
Just re-tried the firmware download and it worked the first try. However the C1 issue is still present as this was caused by the recent DJI GO App update from my understanding.
2016-10-13
NiQWXMY8la10 Posted at 2016-10-14 13:59
OK I know this is a total newbie question, but How can I see the update versions on both the RC and  ...
Could you please clarify which Phantom model you have?If there are updates for your aircraft and RC, the app will remind you.
And you could check the release notes in our DJI websites.
2016-10-13
rpmurph83 Posted at 2016-10-14 14:37
Just re-tried the firmware download and it worked the first try. However the C1 issue is still prese ...
Our engineers will keep improving the DJI GO app.
Please follow the method I mentioned and you will no longer get the popup.
2016-10-13
Aardvark
DJI Mindy Posted at 2016-10-14 08:14
Please follow the method I mentioned and you wil ...
DJI Go informed me of controller update this morning, now updated to V1.8.0
2016-10-14
Aardvark Posted at 2016-10-14 16:29
Thanks for your update.If you have any further query,please feel free to let me know.
2016-10-14
Astronappa
DJI Mindy Posted at 2016-10-14 03:22
As for the C1 issue, please close the DJI Go app, then connect your aircraft with the RC and press ...
Tanks alot Mindy, the RC update has appeared this morning and the C1 button is working as normal again.
2016-10-14
Astronappa Posted at 2016-10-14 16:45
Tanks alot Mindy, the RC update has appeared this morning and the C1 button is working as normal a ...
2016-10-14
Kassur
Now it worked well, updated without any problems
2016-10-14
DJI Natalia
Flight distance : 318 ft
Kassur Posted at 2016-10-14 18:25
That's great, please enjoy it and feel to let us know if any feedback and suggestions, thanks.
2016-10-14
MD_Icarus
Early (brave) beta testers,
Please let the rest of us - nervous- know if this update reduces the range on the P4, or does it improve the streaming video, if you had issues previously.
Also, if you use Litchi, does litchi still work with this update?
Ironically, the GL300A/P3A is putting out more power and it has improved streaming video performance than the GL300C/P4; so I was hoping to see that they improved the GL300C/P4. Is it a typo maybe?? Did they mean GL300C?
DJI please confirm that this update helps video streaming on the GL300C/P4 as well?????(so users do not have to use range extenders)
2016-10-14
Aardvark
MD_Icarus Posted at 2016-10-14 12:23
Please let the rest of us - nervous- know if this update reduces the ran ...
From the release notes:-
"What’s New?
 Improved video stream quality when using GL300A Remote Controller to record 2.7K video.
 Enhanced Remote Controller and mobile device connection stability.  "
The first bit won't help you, but the second might.
2016-10-14
timjd3
DJI Mindy Posted at 2016-10-13 20:49
And it's fix n ...
And it works now.   Thanks.
2016-10-14
MD_Icarus
Aardvark Posted at 2016-10-14 08:06
"What’s New?
Do you think they mean improved streaming video to the device, or the actual sd card video?
I assumed it was the video streaming back to the device.
2016-10-14
Aardvark
MD_Icarus Posted at 2016-10-14 14:27
I assu ...
My understanding is that the GL300A video stream from the aircraft has been improved, but only when aircraft was recording 2.7k video. Looks like there was a problem that they have fixed.
Presumably the video stream from the GL300A works OK when aircraft recording in other modes.
The enhanced RC to Device connection stability presumably will help iron out some of the artifacts seen on some devices.
2016-10-14
1234567Next >
