jakeyzack
If I could upvote this issue 1,000 times I would! This issue is critical!
I have the same setup and the same problem. Matrice 100 with the Zenmuse Z3. I can move the gimbal up and down but not left and right, and can't utilize the optical zoom. Like you precisionflying, I first tried installing the Matrice 100 + X3 firmware via the SD card with no luck. I Then tried the Inspire1 + Z3 firmware (obviously the drone is different but the camera matches) and that didn't work either. To make it worse, I tried checking my current firmware using DJI Assistant 2 via USB plugin, and my computer doesn't recognize my Matrice 100 (I tried this on both Windows 10 and Windows 8 machines).
I called DJI support and they confirmed there is currently not a firmware package released for the Matrice 100 with the Z3, and suggested that I disconnect my Z3, go find an Inspire1 at a hobby shop, and connect it to that, and maybe the firmware install might work, and connect my Z3 back up to my Matrice (?!?!?). Thanks for thinking outside of the box, but I'm sorry, that's not a feasible solution.
If you're going to market the Z3 as a camera option on the Matrice 100, then please provide firmware that makes this camera functional! |
