Go App doesn't remember custom settings
1281 6 2016-10-15
AEROKAMERA
Flight distance : 2289429 ft
Poland
No version of Go App remember some custom setings. Why DJI programmers?E. g. camera set to movie mode on next launch it always back to picture mode. Framing lines are always off on next launch, etc.
Why do I have to set it all every launch (iPhone6/iPad4Mini)? Is it normal?
2016-10-15
DJI Natalia
Flight distance : 318 ft
Correct, not all the parameters will be save into camera settings. Some of them will be back to default after restarting, such as grip and picture mode. While some will be saved, such as resolution, exposure compensation.
In that case, you need setup the parameters manually.
2016-10-16
AEROKAMERA
Poland
DJI Natalia Posted at 2016-10-17 09:13
Correct, not all the parameters will be save into camera settings. Some of them will be back to defa ...
OK, thanks
2016-10-17
cinematic_aero
Flight distance : 540331 ft
@DJI Natalia Can the app or the aircraft please be programmed to save all the settings upon turning the aircraft or app off? When switching batteries quickly it is so annoying to have to spend time going through and checking everything again. Don't see a reason why the system can't just save everything so it is exactly the same upon rebooting. This is what every other professional drone I have used does. If you have a way to pass suggestion on to developers that would be great.
2016-10-18
AEROKAMERA
Poland
cinematic_aero Posted at 2016-10-18 18:40
@DJI Natalia Can the app or the aircraft please be programmed to save all the settings upon turning  ...
Keep your fingers crossed
2016-10-18
Bullcrappy
Flight distance : 87989 ft
This is terrible, it loses setting like I put it into bracket mode AEB 5 and even changing modes it loses settings and reverts back to single shot.  also some time j+R turns off and it goes back to jpg only...smh
2017-5-20
Bullcrappy
Hey guys n girls... how is now one talking about the fact that P4P/Go 4 app crashing a good bit
and bigger deal is it loses setting between power cycles.. it regularly goes back to .mov after I set it to .mp4
AE lock gets turned off just after stopping recording
I set it 5 brackets and it goes back to single shot
etc...
no issue with P3P or the older app
I am guessing this will be fixed next fw? hoping...
i only found one reference to this on the forum..seems like a bigger deal to me hmmm
2017-5-24
