Osmo Handwheel to focus Inspire pro camera.
4548 29 2016-10-18
fh1thd
Flight distance : 92297 ft
Hi, can I use the DJI Osmo Handwheel (Part 76) to focus the inspire pro camera?
with best regards,
Freddie
2016-10-18
Hi Freddie, the Osmo Handwheel cannot be used on the Inspire.
2016-10-19
DJI-Jamie
Flight distance : 112405 ft
As Mindy said, you can not use the OSMO handwheel with the Inspire, but you can use the normal Follow Focus with both the Inspire and the OSMO.
2016-10-20
fh1thd
Thanks for you response.
Too bad it would be a nice affordable solution.
2016-10-22
AEROKAMERA
Flight distance : 2289429 ft
Poland
DJI-Jamie Posted at 2016-10-20 21:09
As Mindy said, you can not use the OSMO handwheel with the Inspire, but you can use the normal Follo ...
Are the I2 focus handweel and  Osmo focus the same or can I use it with I1Pro?
2016-11-19
DJI-Jamie
AEROKAMERA Posted at 2016-11-20 01:44
The hand wheel can be used between the I2 (with adaptor cable)  and the OSMO, but it still will not work for the Inspire 1. The regular DJI Focus Remote can be used between all 3 platforms.
2016-11-19
AEROKAMERA
Poland
DJI-Jamie Posted at 2016-11-20 00:08
The hand wheel can be used between the I2 (with adaptor cable)  and the OSMO, but it still will no ...
Any chance to have handweel focus to work with I1Pro? I prefere to mount it on my RC. So I would buy second RC and Osmo
2016-11-20
DJI-Jamie
AEROKAMERA Posted at 2016-11-20 16:02
Any chance to have handweel focus to work with I1Pro? I prefere to mount it on my RC. So I would bu ...
Unfortunately the handwheel is not compatible with the Inspire 1 RCs, as it does not have the cabling needed to connect. The Follow Focus remote is the only accessory that is compatible across all platforms.
2016-11-29
AEROKAMERA
Poland
DJI-Jamie Posted at 2016-11-29 18:30
Unfortunately the handwheel is not compatible with the Inspire 1 RCs, as it does not have the cabl ...
Is a cable a problem only? Follow Focus doesn't fit my expectations, I'd rather buy third party FF
2016-11-29
DJI-Jamie
AEROKAMERA Posted at 2016-11-30 02:26
At this time, yes that is what is causing the compatibility issue. I do not know whether an adaptor cabe is in the works, but I can check.
2016-11-29
fansd706ca75
Come on DJI, give us the cable
2016-12-2
fansd706ca75
http://store.dji.com/product/han ... d-inspire-2rc-cable
This cable is not suitable?
2016-12-3
dopey-tree
Flight distance : 6716467 ft
To be honest though do you need a focus wheel when flying in the air? Focus pulling is usually more for going from close focus to far etc. Just from personal use the drone is normally say minimum 2 meters away form something, I only ever use the focus wheel on the OSMO rather than the inspire. But I'm sure it could be done in the air. Maybe a really quick cool shot from close up to really high really quickly? But again you could just use a high aperture like f14 etc.
2016-12-3
Skyclip
Flight distance : 347940 ft
DJI-Jamie Posted at 2016-11-29 11:05
Hi Jamie!
Im also interested in that Solution. If it´s only the Cable, does that one fit:
Please keep us up with some news!
2017-1-14
DJI-Jamie
Skyclip Posted at 2017-1-14 09:19
Hi Jamie!
The CAN connection for the Inspire 2 is shaped slightly differently from the Inspire 1. It would not fit properly.
2017-1-17
Skyclip
Hey Jamie!
Did you check, if an adaptor Cable will become available?
Thanks for your help!
2017-1-25
DJI-Jamie
Skyclip Posted at 2017-1-25 08:37
Hey Jamie!
I haven't received an update on the inquiry. I can check again, though there will be a delay due to the Chinese New Year holiday.
2017-1-25
Skyclip
DJI-Jamie Posted at 2017-1-25 11:49
OK, would be nice if you keep us updated.
Thanks for the effort. :-)
2017-1-25
DJI-Jamie
Skyclip Posted at 2017-1-25 23:35
I'll let you know what I find out.
2017-1-26
nobbe
Flight distance : 448573 ft
Hi everybody!
I had a closer look at the cable issue and found out that the "old" plug of the NAZA GPS will perfectly fit the CAN Bus port on the Inspire 1 remote. Just have a look at the pictures attached.
So theoretically one could make up a cable by taking a regular focus handwheel can bus cable and just ripping of the plug at one end. Then connect the old GPS plug to the free cable end and try it out!
However I have no pinout on either connection. So if anyone could come up with a pinout I would make a test cable and post the results!
strange... picture won't work - so here is the direct link to flickr:
https://www.flickr.com/photos/no ... /dateposted-public/
2017-2-13
nobbe
... This plug could also work for Inspire 1 CAN bus port on remote - of course one has to remove the locking clamp...
https://www.reichelt.de/Molex-Vi ... 185729&GROUPID=7981
2017-2-13
Skyclip
nobbe Posted at 2017-2-13 03:31
Hi Nobbe!
Gruss aus Frankfurt ;-)
As Jamie didnt reply to my PM or reply here in the Thread i did my own research with some help from RcGroups.com guys.
Sure, the needed Cable and Plugs are available. The Main Problem could be the following:
I probed the Pins.
PinOut of the Inspire Remote should be(seen from front, left to right):
GND, Can-H,Can-L, Nothing.
At "Nothing" there should be at least the CanBus Voltage of 5.5Volt. But there is nothing.
Reasons could be : Disabled in Firmware or simple Missing Hardware inside the Remote.
In the Manual of the Handwheel is stated that 12Volt is the operating Voltage of the Handwheel.
The only suitable Voltage coming out of the Osmo X5R to Handwheel Connector i could find was 7Volt.
Could be, that Handwheel has some Tolerance of supply Voltage to work.
Would be Interesting if someone could  Probe the CanBus Out of the Inspire 2 Remote, to see the difference or what supply Voltage is provided.
At the Moment i dont have the Time to do more Testing. In the End its a very vague thing to do with no help from DJI.
2017-2-14
nobbe
Skyclip Posted at 2017-2-14 08:13
Hi Nobbe!
Ha! Gruß zurück aus Stuttgart
O.K. - Thanks for the info!
Like you I also just hoped that DJI would come up with some help on a rough pinout description - however no reply since now.
As far as I know the DJI Focus (I'm referring to the hand unit of this remote follow focus system - not the Focus Wheel) hand unit comes with its own built in power supply and this hand unit "officially" works with OSMO pro AND Inspire pro/RAW. So the reason why the DJI Focus hand unit works could be that the missing CanBus Voltage is supplied by the hand unit itself?
So if someone out there has a DJI Focus a pinout reading would be interesting especially the CanBus Voltage pin...
2017-2-20
Skyclip
After a lot of research, i finally got the Handwheel working with the Inspire 1.
Im still in testing, i will soon publish my knowledge to the people who would also like to use the Handwheel with their Inspire 1.
2017-4-9
DarrenE
Awesome work Skyclip. Congratulations on the result and well done for persevering with it. If the wheel can be mounted on a printed bracket or something, that could be pretty handy.
I guess the question will be, how usable it is in operation. That question seems to be one that's already raised it's head on the I2 - http://forum.dji.com/thread-91630-1-1.html
It would be very interesting to hear your opinion on it too. When I was mulling over the idea of a focus wheel for the Inspire, having seen one in use, I ended up thinking the programmable buttons on the more expensive unit were what gave it the most versatility but couldn't justify the price based on that.
2017-4-9
Skyclip
DarrenE Posted at 2017-4-9 12:42
Hi Darren,
mostly, it will make the work of my Camera Operator a lot easier. We are using the Hoodman, and even you can access the touch screen with the hoodman its a lot easier to keep the camera focused on the Object, if you can pull the Focus with a Handwheel at large apertures.
In the end its a lot smoother with the Handwheel, imagine the object getting slightly out of focus, with the Go App and Touchscreen you will see the refocus in most cases. With the handwheel you are more likely to correct the focus "softly".
That are the most important points for me, lets see what creativity on Set will bring additionally. ;-)
For the mount, i may go with the DJI Solution, even if its expensive. Seems very solid and you can mount the Remote on a Tripod.
2017-4-9
Advocate
Flight distance : 1076909 ft
I'm really interested in this solution as I have just bought a new Osmo Pro, and have an Inspire 1 on its way from an eBay auction, being able to use the focus wheel on both platforms would be amazing.
2017-4-10
Skyclip
Published it on Inspirepilots.
Here you go : http://www.inspirepilots.com/thr ... pire-1-howto.16084/
2017-4-11
Advocate
Thank you!
2017-4-13
igoraf
Flight distance : 589596 ft
This cable will not work?
https://www.dslrpros.com/dji-focus-remote-controller-can-bus-cable.html
2019-9-15
