It is a shame there is no obvious way of charging a Mavic battery using a USB port.
I currently use a LiPo to charge my smart phone, not the smartest/efficient way to source power, however as a certain company is only really interested in profit and not allowing their users to swap mobile batteries (the most efficient way), it is the best solution with the resources possible.
This has been very well covered by Henry Mo-Yung (so I am not going to repeat the maths etc here)
https://forum.dji.com/forum.php?mod=redirect&goto=findpost&ptid=67101&pid=525652&fromuid=689714
and his reasoning of "just carry another DJI battery" is faultless for an over night or short hike.
For a more long term solution for a longer hike over many weeks, carrying multiple batteries to cover that time is just not practical due to weight and space.
I would recommend 2 batteries, a solar panel and using the new Spark drone. I have a RAV Power folding solar panel for charging my kit via USB (smart phone, secondary 4G dongle, AA batteries). (Other solar panels are available, however I personally like this one)
On a sunny day this solar panel will put roughly 2Ah (measured) or 10Wh back into the auxiliary LiPo battery or my phone while hanging off my back pack while I am walking. This would be more if the panel as consistently pointing toward the bare sun (as I walk sometimes the panel as shadowed or I am facing away from the sun).
The only issue is the amount of energy required to launch and hold your drone in the air is quite a lot when compared to running other energy efficient devices.
eg
typical smart phone <1900 mAh for a full day's medium use (~ 1.9Ah @1.2 = 2.3 Wh).
but your Mavic battery stores 3.8Ah @ 11.4 V = 43Wh
So I estimate it would take 4-5 days walking in the sun to fully charge one battery using a USB solar panel like this (even if it was possible), providing 27 minutes max flight time (24mins hovering).
So unless your walk is over a week (in good weather), carrying another battery is still the better option.
More than a week and using a solar panel may become a better option.
On a topical note the new and cool Spark can be charged using a USB port.
Typical USB high power sockets provide 0.5A (USB 2) and 0.9 (USB 3), with some proprietary protocols/devices providing more (DJI charging claims 5V/3A and 9 V/2 A; 12 V/1.5 A )
The Sparks battery is
Capacity 1480 mAh
Voltage 11.4 V
Energy 16.87 Wh
This would take 1-2 sunny days to charge, providing 16minutes max flight time (15minutes hovering).
So say we fix the panels charging capacity at 10Wh/day
Mavic battery would charge in 4.3 days and provide <= 24 mins hovering flight (or 5.6 mins of hover time for each charge day)
Spark battery would charge in 1.6 days and provide <= 15 mins hovering flight (or 9.3 mins of hover time for each charge day)
This will be due to the Spark being lighter. So if you don't need 4k resolution (and I don't) and wish for more flight time on your hike while being able to charge your drone away from the grid, the Spark is probably ideal.
Estimated charging time for Spark Intelligent Flight Battery (fully flat) via USB using
Using DJI's charger; ~ 1hr 12min
Using a propriety 2A changer; ~ 1hr 36mins Using a USB 3 high power socket: ~ 3 hrs 45mins Using a USB 2 high power socket: ~ 6 hrs 45mins
I found this an interesting exercise. I hope someone else does too.
This was all calculated using information gathered from the web. Please read your manual carefully before attempting to charge.. eg. don't blame me if any of this is incorrect or any actions taken by you after reading this causes your equipment to expire prematurely.
Have a nice day! :-)
