Geronimo13
Flight distance : 529721 ft
DJI-Jamie Posted at 2016-10-25 09:14
If you have an older version of the Go app available, I would recommend trying to revert back in order to better troubleshoot. Alternatively, the Android version of the Go app also recieved an update today called v3.0.1. You can see if it persists. Just to clarify, are you running the latest firmware on all your units? Did you happen to perform any firmware updates around the same time as the app updates?
For the EXIF data, it's only able to measure from what is recorded as ground level and not sea level.
OK, new mission done 2 weeks ago with same troubleshooting.
Config M100 firmware : 1.3.1.00
App version: 3.1.2 (may be 3.1.1 3 weeks ago)
RC: 1.8.0+
Have a look on this 2 pictures taken at the same real altitude around 25-30m, at the same time (+/- 30 secondes)
Exif Altitude values are completly different and inconsistent:
picture 1: 6,10 m (which was not the true value compared to ground level by the way)
picture 2: 0.20m.
a lot a picture done with simular errors.
Hoping you will identify your issue specially with the new GroundStation Pro application I plan to use for 3D modeling. (Not possible today with inconsistent Altitude value)
picture 2: Exil Altitude = 0.2 m !!
picture 1: Exif altitude = 6,40 m !
