pedrodb
I've been having a hard time getting my inspire 1 to work and have failed to get it working.
So, I downloaded the newest DJIGO app and fired on the RC and aircraft. The app read that I needed to update the firmware on aircraft, battery and RC. I downloaded the firmware on the app and let it install the update. I lost connection to the aircraft... The aircraft was in travel mode with blue light... I then read multiple forums online and tutorials and realized I should have updated the aircraft first then the RC... I then downgraded the RC firmware and re-linked the aircraft using the little red button on the AC and doing the three button reset on the RC. I was able to establish a link and take my inspire out of travel mode. I then turned off the RC, put the gimbal with the new firmware on SD card and turned on the AC. The AC did the little dance with gimbal and then did a blinking yellow light with the double beep. I thought it was updating and let it run for over an hour and half waiting for the green light... but never got it. I took out the SD card but never got a text file at all. I turned on the RC and AC and app and it read that the gimbal was disconnected even thought it was attached. I've gone back and forth for the last few days updating and downgrading firmware, relinking RC and AC but still can't get the gimbal to be recognized in the app. So I can't update the AC as its not reading the gimbal.
I borrowed a friend's inspire 1 to see if it was my camera that had gone bad but it seems to connect fine to his AC. When I attached his gimbal however the AC did not do the dance when I turned on the AC with his camera.
At this point I'm not sure what to do and I'm hoping you guys can help me resolve this and get the AC off the ground in working order.
Thanks,
