Your Best Photos from your Phantom
2129 25 2016-10-25
glowingsplint
Flight distance : 832641 ft
Here are a small collection of mine, all taken with the Phantom 3 adv
2016-10-25
hallmark007
Flight distance : 9827923 ft
There lovely what softwear are you using in post, good job
2016-10-25
glowingsplint
hallmark007 Posted at 2016-10-25 18:34
Cheers, a just use Lightroom and some photoshop to clean stuff up.  The most important thing with the pictures is having taken them using Nd filters.  The more control you have with taken the photo helps massively when your editing them afterwards, well that's my theory
2016-10-25
2000vadasz2
very good job. i love the editing. so do you recommend nd filters?
2016-10-26
2000vadasz2
2016-10-26
labroides
Flight distance : 9991457 ft
2000vadasz2 Posted at 2016-10-27 00:41
ND filters might be useful for video but not for stills on a Phantom.
2016-10-26
visitkans
Flight distance : 80413 ft
+1 to the above post, ND filters on a Phantom are not that important, coming from a DSLR background, i use them for slowing down the shutter speed when photographing waterfalls to show a movement effect on the water, but on Phantom unless there a reason you need a slow shutter, you wont need an ND, a Polariser will be most useful, but getting the polariser at the right orientation will be a tricky one.
2016-10-26
glowingsplint
visitkans Posted at 2016-10-26 16:54
+1 to the above post, ND filters on a Phantom are not that important, coming from a DSLR background, ...
Having more control over highlights is why a use them, on a mirror-less or dslr sure a only use them for slow shutter stuff.  A only use the phantom in really bright conditions am surprised by people not using them to have a wee bit more control.
Do you have any examples of your photography from the drone in sunshine, just so a can see if am doing something wrong
Stuart
2016-10-26
glowingsplint
2000vadasz2 Posted at 2016-10-26 14:42
A use a Nd8 filter most of the time, don't just take my word for it though check out examples of people's pictures taken with them not just their words
2016-10-26
skyticlus
Flight distance : 322684 ft
here are a few i like of my collection, not edited and without any filters ...
2016-10-26
glowingsplint
skyticlus Posted at 2016-10-26 20:26
Great stuff always like seeing what other people can do with these machines
2016-10-26
skyticlus
glowingsplint Posted at 2016-10-27 03:37
Thank you, i hope to be able to edit some like you, i'll make sure to share some more sometime soon
2016-10-26
visitkans
glowingsplint Posted at 2016-10-26 19:21
Having more control over highlights is why a use them, on a mirror-less or dslr sure a only use the ...
Hi mate,
Its definitely not wrong, did not mean that, an ND on a quad is more apt for videos, because videos need a slower shutter speed to show movement....
so by using an ND, all you do is slow down the shutter speed in turn allowing more light for a mean exposure for the scene, so control of highlights are not really achieved by an ND, you are essentially exposing the same scene in a different shutter speed, instead of say 1/1000, you might expose at 1/500.
if you are using a split or a graduated ND then you have a different exposure on the different parts of the image.
Here are 2 images of greater dynamic range situations, you can take 5 or 3 exposures in AEB mode and then merge them together to get better control of highlights.
this one is using a DSLR Canon 5D (3 images merged, would have preferred 5, my bad)
This one is no the P4 (5 images merged)
http://www.vividscapes.com/images/fotos/dji_1.png
As an experiment you can try with and without ND, if you get an exposure of 1/1000 without an ND, and 1/500 with an ND, turn the exposure wheel on the phantoms controller to get 1/500 and see the results.
These are just my understanding of the basics of ND and photography, happy to be proven otherwise if an ND really makes the exposure different.
2016-10-26
glowingsplint
visitkans Posted at 2016-10-26 21:29
Hi mate,
Its definitely not wrong, did not mean that, an ND on a quad is more apt for videos, bec ...
Your photo is a prime example of what am talking about, your highlights around the sun look over processed.  A find it really surprising anyone that has ever used a camera doesn't use them when needed to put the sunglasses on the camera.  Check out my proper camera stuff here https://www.facebook.com/Hilophotography
2016-10-26
johnlega
Here are a few I shot while in Ideyllwild, CA. Not great but I'm happy with them.
2016-10-26
visitkans
glowingsplint Posted at 2016-10-26 21:38
Your photo is a prime example of what am talking about, your highlights around the sun look over p ...
Its not over processed, its because of the high dynamic range and just 3 photos in the merge, thats why i said need 5 to get the exposure right.
fine if you think sunglasses are the answer to getting the highlights correctly exposed, then thats not the right approach, but am not going to argue here.
Again an ND has a different use, not what a lot of people use for getting a better exposure.
2016-10-26
glowingsplint
visitkans Posted at 2016-10-26 21:52
Its not over processed, its because of the high dynamic range and just 3 photos in the merge, that ...
A really think your missing what am saying or am not communicating it properly.  Either way have a good day and keep doing what you feel works best.
2016-10-26
glowingsplint
johnlega@gmail. Posted at 2016-10-26 21:43
The second photo in particular is stunning, the mountain looks really imposing
2016-10-26
2000vadasz2
glowingsplint Posted at 2016-10-27 02:22
A use a Nd8 filter most of the time, don't just take my word for it though check out examples of p ...
ok thank you so much!
2016-10-26
fans95097035
labroides@yahoo Posted at 2016-10-26 22:26
Ok thank you
2016-12-2
ErC...
stunning photos... thanks for sharing...
2016-12-30
ePetLicensing.c
Her is one from THE FALL!
PA FALL
2016-12-30
ePetLicensing.c
This afternoon with the Mavic Pro in North Myrtle Beach fighting with the sun glare!
Fighting the sun glare with the Mavic Pro
2016-12-30
WYHSniper1007
Flight distance : 1003822 ft
Nice!Good Job!
2017-1-3
Sloan Fischer
WOW COOLEST PICS IVE EVER SEEN
2017-3-10
Adam Flurk
Flight distance : 425466 ft
Great job! The photos came out great. Def a good job with processing.
Figured I'd include some of my favorites. Haven't been up in awhile, need to update
2017-3-13
