New Z30 camera
1987 6 2016-10-25
pinpointmapping
Flight distance : 5345105 ft
I'm curious if the newly announced Zenmuse Z30 camera will work on the Inspire and Osmo (or just the Matric) and of course, since it has been announced, will it be delivering before Xmas?  Thanks
http://www.dji.com/zenmuse-z30/info#specs
2016-10-25
Farnk666
Flight distance : 1711394 ft
It is Matrice only.
2016-10-25
pinpointmapping
really?  Can you tell me how the Matrice is different than the Inspire?  The controller is the same I thought and so is the mounting for the camera, so I don't understand how the Z30 would only work with the Matrice.  If it only works with the Matrice, that seems very short sighted on DJI's part.....
2016-10-26
Farnk666
pinpointmapping Posted at 2016-10-27 05:18
really?  Can you tell me how the Matrice is different than the Inspire?  The controller is the sam ...
Feedback is that it is a weight issue and that the payload is not supported for use on Inspire.
The two Matrice airframes can manage heavier load.
2016-10-26
DJI-Jamie
Flight distance : 112405 ft
Farnk666 is spot on. In addition, the Matrice series (the M100 and M600) and the Z30 are considered industrial products. Industrial platforms have access to Onboard SDK and use accessories to reinforce the stability needed to perform industiral jobs.
2016-10-27
fans694dfe25
Flight distance : 6716467 ft
Mmmm can you feedback to dji that this may be wanted on the inspire, I'm sure it can be made to work. It's not a weight issue as: X5RAW 583g vs Z30 556g
2016-11-2
fansd2e77d65
fans694dfe25 Posted at 2016-11-2 05:47
Mmmm can you feedback to dji that this may be wanted on the inspire, I'm sure it can be made to work ...
This is for the Inspire 2.  If they made it work on the Osmo or Inspire 1, they would reduce demand for the coming Inspire 2...
2016-11-2
