Can't remove controller joysticks?
123Next >
12370 92 2016-10-28
Eazy123
I don't see anything in the manual about this, but it was said to be a feature. I can't seem to figure it out. Any ideas?
2016-10-28
Tahoe Ed
Flight distance : 41668330 ft
The design was changed before production was shipped.
2016-10-28
Logger
Flight distance : 2883714 ft
Ah glad I found this.
Would have broken my Joysticks trying to unscrew them to fit in the case. So the are fixed and not to be removed. Good to Know.
2016-11-1
giusis00
It's really bad now.. it doesn't even enter inside his bag (the joystick touches the side and moves.. with the time the spring can get some memory on that side).
2016-11-1
MadMonkey
Do they screw out at all, is the length at least adjustable?
2016-11-2
Repsolkid
Flight distance : 7418 ft
MadMonkey Posted at 2016-11-2 08:21
Why did they not just leave them as removable? Seems a backward step in design to me.
2016-11-2
fansa7eabb8f
Flight distance : 892703 ft
I also fell uncomfortable stuffing the control into a bag with a non neutral position for the sticks. I used the foam case form the battery, cut it to the size of the controller, and cut two holes in which I insert the sticks. The sticks are then stable and stay in position.  Not pretty, but works great.  I'm sure someone will come up with a custom protection sleeve
2016-11-2
circumvolo
Just pull and they come out very easily. There's no screw or anything. Highly recommended for storage!
2016-11-2
circumvolo
Tahoe Ed Posted at 2016-10-28 22:27
The version I received on Monday (Combo) has removable sticks...
2016-11-2
dana5
Flight distance : 14354 ft
circumvolo Posted at 2016-11-2 23:31
Yes, but you were not actually supposed to break them off!
Seriously? Yours pop out?
I was actually hoping that they would keep that as a feature, so that they could be upgraded from plastic to aluminum, and possibly have adjustable length, like those on the P4 controller.
2016-11-2
Andy Sayle
Flight distance : 3358875 ft
I'd love to be able to fit some adjustable length sticks, or even just some longer sticks to increase the precision that can be acheived....
2016-11-2
circumvolo
dana5 Posted at 2016-11-2 12:00
Yes, they just come right out when you pull. I store them in the mesh part of the Combo bag right above where the transmitter and drone go.
2016-11-2
circumvolo
See? Easy removal.
2016-11-2
tV1fr835Dcq3
circumvolo Posted at 2016-11-3 03:43
See? Easy removal.
Hmm.. interesting. I guess maybe you got one of the older units before they changed the design? That or the DJI person above is incorrect? I'll have one tomorrow, I'll see if mine can be removed.
2016-11-2
fans7313fddb
Mine do not come out like that... I do not want to put in more force - afraid to break it.
2016-11-2
circumvolo
fans7313fddb Posted at 2016-11-2 16:15
Oh great... If this sort of thing is different, I wonder what else could be?
2016-11-2
Andy Sayle
Just checked mine.  There is no way they are coming out easily.  I'm pulling on them as hard as I dare, and they don't budge...
Andy
2016-11-2
quanthonytrang
Flight distance : 419980 ft
Maybe this explains why there are a few with the MECH ERROR issue where the sticks are not registering dead centre when released. Some of these have caused crashes and loss of control. DJI could of made a few variants with the controller. If you are concerned, use the simulator to test your controller.
Can everyone post up there controller version/serial number and mention if their sticks are removable or not.
I know in the P3A/P range there was GL300a/b/c. It could be the same case here.
2016-11-2
fansb5610756
Flight distance : 459 ft
My Mavic also doesn't have removable sticks, which is very disappointing - it makes a nontrivial difference to the size of the sleeve required for the controller.  I've been discussing it with DJI support directly, & they keep going back and forth about whether it's supposed to be removable or not.  Seems to be extremely disorganized / poor communication within the company...
2016-11-3
DJI-Ken
Flight distance : 1515312 ft
circumvolo Posted at 2016-11-3 04:32
If you like, I can see about exchanging your RC to the production version RC.
2016-11-4
Nobelcat
DJI-Ken Posted at 2016-11-5 00:17
How would we distinguish production from an earlier version?  Anything different in the model or serial number?
2016-11-4
fansf29a9bd8
Banned
2016-11-4
DJI-Ken
fansf29a9bd8 Posted at 2016-11-5 00:59
Hilarious. They are sending out pre-production equipment to the early orders.
It may very well have been this way for the very first few of production versions and then changed. I don't work in R&D so I don't know.
2016-11-4
DJI-Ken
Nobelcat Posted at 2016-11-5 00:50
How would we distinguish production from an earlier version?  Anything different in the model or s ...
As my above post stated, versions are changing all the time, the removable sticks could have been the very first production version then changed after some orders were sent out.
On the Phantom, the 2nd version of the P3 got different motors and centerboard.
On the Mavic I do not know what differences may have been or will be.
2016-11-4
ngvuanh
Flight distance : 159820 ft
I think DJI just wanted to avoid future complaining that the sticks are loose or even lost.
Obviously, removable sticks are great but it will be loose over the time and may be dropped out without knowing it.
2016-11-4
fansf29a9bd8
Banned
2016-11-4
Visualkaos
Flight distance : 755988 ft
giusis00 Posted at 2016-11-2 15:55
It's really bad now.. it doesn't even enter inside his bag (the joystick touches the side and moves. ...
You can put the contoller in sitting diagonal with the sticks facing the corner and they then stay neutral.  I didnt like the fact they were off center either and figured out this solution.
2016-11-4
giusis00
Visualkaos Posted at 2016-11-4 19:42
You can put the contoller in sitting diagonal with the sticks facing the corner and they then stay ...
It's what I'm doing already.. but the controller won't stay diagonal for long. I also have the two additional batteries in the outside pockets that does additional pressure on the side, so this solution isn't working good. Another option would be to place some custom caps over them.
2016-11-4
Visualkaos
giusis00 Posted at 2016-11-5 02:52
It's what I'm doing already.. but the controller won't stay diagonal for long. I also have the two ...
yeah the caps might be a solution.  I found that the 2 batteries fit in the front pocket and then that makes it a little looser fit for the mavic and controller instead of having them on the sides.
2016-11-4
Heniek W
fansf29a9bd8 Posted at 2016-11-4 10:59
Bwahahaha , really lol
2016-11-4
Heniek W
DJI-Ken Posted at 2016-11-4 11:15
It may very well have been this way for the very first few of production versions and then changed ...
Just like GMC lol
2016-11-4
Eazy123
Doesn't bug me. I put the controller in diagonally and can also fit the Mavic, both extra batteries and the charger just fine.
2016-11-4
DJI-Ken
If the stick are fully deflected to the side/top/bottom it is 100% fine and will not hurt anything.
2016-11-4
giusis00
Eazy123 Posted at 2016-11-4 22:55
Doesn't bug me. I put the controller in diagonally and can also fit the Mavic, both extra batteries  ...
In the original DJI bac? How they are disposed? And the controller sticks doesn't touch anything (they doesn't move)? Tell us about your magic...
2016-11-4
Nobelcat
DJI-Ken Posted at 2016-11-5 01:18
As my above post stated, versions are changing all the time, the removable sticks could have been  ...
I'm not asking what features existed or will exist in the future in the controllers.  I'm asking if there's a way to identify (ie, model number) if we got a controller that isn't the production model.  Most companies have a different part number if the object was changed in any way.  Is there a way I can look at the serial number or model number and identify if I have the current model of the controller?
2016-11-4
DJI-Ken
Nobelcat Posted at 2016-11-5 10:07
I'm not asking what features existed or will exist in the future in the controllers.  I'm asking i ...
What I'm saying is you have the current RC.
Why do you ask? Does your RC have an issue?
2016-11-4
chippie
Flight distance : 12976 ft
My model number is GL200A - I have removable sticks!
I very much doubt there is already a "B" version out. I have a feeling that everyone has the GL200A and all sticks are removable. The exception being that some have simply been pushed in really hard during production and hence are a lot harder to remove. From what we know from DJI they are not region specific so the model number should not change with regards to this.
So, anyone have a different model number to GL200A?
2016-11-5
040mike
Flight distance : 29045 ft
chippie Posted at 2016-11-5 11:42
I very much doubt there is already a "B" versi ...
@chippie
is there a piece of metal at the end of the stick? or maybe inside the plastic? pls try to find out with a magnet ;-)
2016-11-5
chippie
040mike Posted at 2016-11-5 12:50
@chippie
No metal, no magnets, the hole does NOT go all the way through to the controller. It is a molded hole.
Well, I think the sticks themselves are an alloy anyway but there is no additional metal etc...
2016-11-5
040mike
chippie Posted at 2016-11-5 13:58
No metal, no magnets, the hole does NOT go all the way through to the controller. It is a molded ho ...
OK Thnx ...
2016-11-5
123Next >
